Sponsored by: CARiD
Front Diff 4Matic - Sealed?
Old Sep 10, 2017 | 06:14 PM
Mud's Avatar
Mud
2011 E-350 4Matic Sport
So I decided to change out the front/rear differential fluid today. The rear diff was pretty simple - the fill and drain plugs were readily accessible. Car was raised and leveled, took about 1.2 qts.
But when I got to the front, I could not find a fill plug? I looked online at some diy stuff on the front, but where I expected to find a hex plug, there is a seal, looks like a small freeze plug. Definitely factory installed. I did find what I thought was an 8mm hex drain plug right on the bottom of the diff, but there was nothing else up higher on the unit.
Online info showed an 8mm hex plug just to the right of the passenger side axle shaft. As mentioned in my case this is a flat seal not designed to be removed.
What am I missing? I know that the transfer case shares fluid with the transmission, but I was expecting the front diff to have its own fluid.
Old Sep 11, 2017 | 10:22 AM
ijain314's Avatar
2013 E350 Sedan
I ran into the same issue. I talked to my local MB dealership. They claimed that in order to drain the front diff, both the half axles have to come off....not sure if I trust them.
Old Sep 11, 2017 | 10:33 AM
Mud's Avatar
Mud
Wow ...That's crazy just to avoid threading in a fill plug! But who knows maybe so that 30 min job can take hours and $$ !
I'll ask the dealer since I have to take it in for a warranty item anyway. Thanks for verifying that seal.
Old Sep 12, 2017 | 11:34 AM
konigstiger's Avatar
'71 Pinto
See here: http://www.benzworld.org/forums/w212...fill-hole.html follow link in post 5 http://www.benzworld.org/forums/w212...l#post16285034
Old Sep 12, 2017 | 04:14 PM
Mud's Avatar
Mud
Many thanks sir!
