Sponsored by: CARiD
unknown Noises
Old Sep 13, 2017 | 01:32 PM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
unknown Noises
I have a E350Bluetec and I have a couple new issues. First when I put the car in reverse IE backing out of garage, I get a rattling noise. Once I start going forward it stops. The second issue is when starting out in the morning I get a noise when I let off the fuel to slow down. It sounds like I have a Jake break or something. It only does it for a little bit then goes away. same thing each time a slow down. I believe I can even feel a difference not just hear it. It does seem to stop doing it once it is fully warmed up. Any ideas where to start looking or has anyone experience ether of these?
Old Sep 13, 2017 | 04:09 PM
RA72825's Avatar
Rattling type noises are associated with exhaust components on many occasions. Check the heat shields around the catalytic converters to make sure they are secure and not damaged, bent, etc. Failed motor mounts may be the cause of your other noise.
Old Sep 13, 2017 | 04:22 PM
Rod Spohn's Avatar
Thanks, I'll check those area first. Motor mount definitely makes sense.
