Collision prevention assist
I finally got my car back and had a chance to look over the settings. In Non-Distronic cars go to DriveAssist on your Multi Function Display and go down to Distance Warning and make sure it says “Enabled” now that you are sure the assist is activated, try the steps as other members have suggested above. I literally got 1/4 mile from the dealer after picking up my car and while I was driving and trying to connect my iPhone and not paying attention, a car stopped in front of me and I got the red triangle on the dash and audio warning alerting me to stop.
Sensors: If your car is equipped with Distronic Plus: You have three radar sensors in the front of the vehicle: one in the radiator grille (long-distance unit) and two behind the front bumper. (There are three more radars in the rear bumper, but those serve different purposes including blind spot monitoring and rear collision detection.) If you have Distronic Plus, it also integrates the stereo camera data (2014+ vehicles) to factor in pedestrian detection and some other fringe cases where the radar units may not be detecting the situation appropriately (such as cross-traffic.) If your car is NOT equipped with Distronic Plus, you have one radar unit behind your front bumper, not sure if it's on the left or right side.
Actions: 2015+ vehicles can detect the collision and apply brakes autonomously. 2014 vehicles only warn and prime the brakes. If you have Distronic Plus, due to the additional two radar units, your vehicle can detect potential collisions farther away and at higher speeds. It can also detect stationary objects at higher speeds. I believe PRE-SAFE/Collision Prevention Assist Plus on DTR+ vehicles can operate up to 120MPH or so.
Testing: A towel or cardboard boxes will NOT work. You need a radar-reflective material. I have built a few test rigs of my own to test out the vehicle's capabilities. It takes some time investment to build. You can use cardboard boxes or poster boards as a starting material, but you'll need several layers of aluminum foil as a radar reflective material. The radar units will see right through the cardboard otherwise, and correctly assume that there is no threat to the vehicle. The carboard box(es) or posterboard must be about the width of a car for optimal detection. If you cover it in a few layers of foil and mount it on a stand that can be knocked over without damaging your vehicle, you've built a functional test stand.
When you do test it, drive around the block first, then stop about 30 feet from it. Your vehicle, if equipped with DTR+, should show a car ahead of you. From there, you can accelerate gradually to about 10-15MPH, and the warning should start to go off when you are about 1.5-2 seconds from collision. Braking begins at 0.6 seconds prior to collision, and should stop you just before you hit the test assembly.
I've tried this with my wife's GLK250BT, and my E250BT. The systems work flawlessly, and have saved us before, including while my wife was pregnant. Drive as if you don't have them, but man, when you need them, they can really be a life saver.
Today's radar technology is amazing, but I absolutely believe that the system will not pick up towels or cardboard boxes like you said. However, modern "consumer grade" boat radars will pick up a one to two foot tall PVC pipe sticking up from water (
My 2014 beeps about 5 times on each drive. I did not know about priming the brakes, but I used accelerator pedal instead.
The beeps usually happen when I pass slow traffic on exit lane and have short distance for merging.
I would assume our car radars have an algorithm that seeks for the shape/reflection pattern of a car (or motorcycle?). At least my distronic plus seems to pick up a motorcycle, but maybe the cameras are aiding the radar at that point?
The boating examples are a bit easier - there's less to filter on boat radar, as basically anything that comes up in the path of the vessel is a threat and needs to be avoided. Also, more importantly, the boat works with a human in the loop to interpret the data and weed out false positives. Because roads have turns and complex environments, the algorithms that work on the car need to be a lot more selective about what they report and act upon. As they need to work without human intervention, filtering and eliminating false positives is very important.
I have a MY2014 E350T and it states the following:
266 DISTRONIC PLUS CROSS SUPPORT (DTR+Q)
268 EXPANDED BRAKE ASSIST (BAS+)
269 BRAKE ASSIST PLUS CROSS TRAFFIC (BAS+Q)
271 AUTONOMOUS BRAKE INTERVENTION/WARN. FOR PED. PROT.
300 COLLISION MINIMIZATION BRAKE INTERV./WARNING (CMS)
238 ACTIVE LANE KEEPING ASSIST (FAP)
253 REAR-END COLLISION WARNING AND PROTECTION SYSTEM
Anyway... thanks for the info!! :-)
2. at stop and go traffic, if the car in front of you is stopped for more than 5 seconds, you need to accelerate to start the vehicle moving. But when ECO mode is active, and the engine is turned off during this stop, it'll start the vehicle(when the vehicle in front of you moves away) for you but will not move until you give some gas.
In other words, the sequence can be this if the traffic stops suddenly while DISTRONIC is engaged: 1) Distronic disengages and warns the driver with a sound and visual warning. 2) Driver is supposed to manually break to prevent collision 3) If collision is still imminent, COLLISION PREVENTION ASSIST PLUS gives an audible and visual warning 4) If driver still fails to brake, autonomous braking will (hopefully!) be applied.
Here are the quotes from the manual (I have witnessed the first part, not the second part):
"DISTRONIC PLUS brakes your vehicle with up to 50% of the maximum possible deceleration. If this braking force is insufficient, DISTRONIC PLUS warns you visually and audibly. There is a risk of an accident. In such cases, apply the brakes yourself and try to take evasive action. "
"If COLLISION PREVENTION ASSIST PLUS detects that there is a risk of a collision, you will be warned visually and acoustically. If you do not react to the visual and audible collision warning, autonomous braking can be initiated in critical situations."
I see that system can be disadvantage. I drive often in heavy traffic and have to cut between the cars with small clearances. The system beeps on me quite often, but would hate to be surprised if it pushed brakes in such moment.
That did not happen so far, but what are the limits?
Meaning, the vehicle stops automatically with sudden cross traffic/carts/other objects? or that is only available in S-class?
Thanks.
I had two people who intentionally drove by while I was reversing from a parking lot and the vehicle didn't stop automatically.
We don't need you involved in any more fender benders. LOL
268 - EXPANDED BRAKE ASSIST (BAS+)
269 - BRAKE ASSIST PLUS CROSS TRAFFIC (BAS+Q)
271 - AUTONOMOUS BRAKE INTERVENTION/WARN. FOR PED. PROT.
Yes they are available based on datamb.com
https://www.datamb.com/vin/1eQm3AV5yWW29GW6N
If you want the car to stop on its own in reverse due to cross traffic, that feature is only available in the W213 E-class and newer S-class. Just confirmed, unintentionally, that it works on my car but it works well!
Thanks.
Holding the FOB key for trunk close works on both my 14 E350 and my wifes 17 GLE 350. All the other methods close the trunk too.
One of the things I love about Mercedes, the ergonomics of everything, literally every possible way you could intuitively think of to close and open the trunk, is available to you.
Anyway, I just tested again and NO the Keyfob doesn't close the trunk.
Just being a bit too careful before my ELW ends July 2020. Oh boy, time flies super fast even with this slow E350. (Slowest of the bunch
.Anyway, I just tested again and NO the Keyfob doesn't close the trunk.
