Collision prevention assist
Old 09-20-2017, 07:09 AM
apg231's Avatar
2014 E550 Black on Black
OP,
I finally got my car back and had a chance to look over the settings. In Non-Distronic cars go to DriveAssist on your Multi Function Display and go down to Distance Warning and make sure it says “Enabled” now that you are sure the assist is activated, try the steps as other members have suggested above. I literally got 1/4 mile from the dealer after picking up my car and while I was driving and trying to connect my iPhone and not paying attention, a car stopped in front of me and I got the red triangle on the dash and audio warning alerting me to stop.
Old 10-02-2017, 12:53 PM
bytemaster0's Avatar
2023 EQE350 4MATIC, 2023 EQE 350 4MATIC SUV, 1995 E300 Diesel
So, here's some information that may help:
Sensors: If your car is equipped with Distronic Plus: You have three radar sensors in the front of the vehicle: one in the radiator grille (long-distance unit) and two behind the front bumper. (There are three more radars in the rear bumper, but those serve different purposes including blind spot monitoring and rear collision detection.) If you have Distronic Plus, it also integrates the stereo camera data (2014+ vehicles) to factor in pedestrian detection and some other fringe cases where the radar units may not be detecting the situation appropriately (such as cross-traffic.) If your car is NOT equipped with Distronic Plus, you have one radar unit behind your front bumper, not sure if it's on the left or right side.
Actions: 2015+ vehicles can detect the collision and apply brakes autonomously. 2014 vehicles only warn and prime the brakes. If you have Distronic Plus, due to the additional two radar units, your vehicle can detect potential collisions farther away and at higher speeds. It can also detect stationary objects at higher speeds. I believe PRE-SAFE/Collision Prevention Assist Plus on DTR+ vehicles can operate up to 120MPH or so.
Testing: A towel or cardboard boxes will NOT work. You need a radar-reflective material. I have built a few test rigs of my own to test out the vehicle's capabilities. It takes some time investment to build. You can use cardboard boxes or poster boards as a starting material, but you'll need several layers of aluminum foil as a radar reflective material. The radar units will see right through the cardboard otherwise, and correctly assume that there is no threat to the vehicle. The carboard box(es) or posterboard must be about the width of a car for optimal detection. If you cover it in a few layers of foil and mount it on a stand that can be knocked over without damaging your vehicle, you've built a functional test stand.
When you do test it, drive around the block first, then stop about 30 feet from it. Your vehicle, if equipped with DTR+, should show a car ahead of you. From there, you can accelerate gradually to about 10-15MPH, and the warning should start to go off when you are about 1.5-2 seconds from collision. Braking begins at 0.6 seconds prior to collision, and should stop you just before you hit the test assembly.
I've tried this with my wife's GLK250BT, and my E250BT. The systems work flawlessly, and have saved us before, including while my wife was pregnant. Drive as if you don't have them, but man, when you need them, they can really be a life saver.
The following 2 users liked this post by bytemaster0:
KEY08 (10-02-2017), tresean1 (10-02-2017)
Old 10-02-2017, 02:34 PM
E250_92101's Avatar
2016 E250 BT, 2021 EQC 400
Thank you for sharing such an awesome level of detail with us all!
Today's radar technology is amazing, but I absolutely believe that the system will not pick up towels or cardboard boxes like you said. However, modern "consumer grade" boat radars will pick up a one to two foot tall PVC pipe sticking up from water (
at 3:35), but like you said, I would assume our car radars have an algorithm that seeks for the shape/reflection pattern of a car (or motorcycle?). At least my distronic plus seems to pick up a motorcycle, but maybe the cameras are aiding the radar at that point?
Old 10-02-2017, 08:54 PM
kajtek1's Avatar
Received 1,730 Likes on 1,380 Posts
1922 Ford Model T / no OBD
I don't understand some owners having problem with it.
My 2014 beeps about 5 times on each drive. I did not know about priming the brakes, but I used accelerator pedal instead.
The beeps usually happen when I pass slow traffic on exit lane and have short distance for merging.
Old 10-03-2017, 09:55 AM
Tump43's Avatar
2014 E350 4Matic
same for me
Old 10-03-2017, 12:41 PM
Glad to do so! I'm a bit of a fanatic about this technology. So, with respect to motorcycles, yes, it's a dense, radar-reflective surface, and large enough that Distronic Plus will see it. I believe that the manual has a disclaimer about motorocycles or smaller vehicles like bicycles, but the radars still seem to see them just fine.
The boating examples are a bit easier - there's less to filter on boat radar, as basically anything that comes up in the path of the vessel is a threat and needs to be avoided. Also, more importantly, the boat works with a human in the loop to interpret the data and weed out false positives. Because roads have turns and complex environments, the algorithms that work on the car need to be a lot more selective about what they report and act upon. As they need to work without human intervention, filtering and eliminating false positives is very important.
Old 03-27-2018, 02:57 PM
  #32
Exup99's Avatar
E350T Bluetec
Thanks for the explanation, but I think the part where I marked at Bold is not entirely correct??
I have a MY2014 E350T and it states the following:
266 DISTRONIC PLUS CROSS SUPPORT (DTR+Q)
268 EXPANDED BRAKE ASSIST (BAS+)
269 BRAKE ASSIST PLUS CROSS TRAFFIC (BAS+Q)
271 AUTONOMOUS BRAKE INTERVENTION/WARN. FOR PED. PROT.
300 COLLISION MINIMIZATION BRAKE INTERV./WARNING (CMS)
238 ACTIVE LANE KEEPING ASSIST (FAP)
253 REAR-END COLLISION WARNING AND PROTECTION SYSTEM
Anyway... thanks for the info!! :-)
Old 03-27-2018, 04:34 PM
  #33
KEY08's Avatar
Received 1,616 Likes on 1,186 Posts
2014 E550-sold 😩
I have that code 271 in my 2014 E550 as well, but I believe the autonomous braking part relates only to speeds below 35, where Distronic Plus will indeed follow the car directly in front of you and slow to a complete stop, while also accelerating completely on its own to your set speed. It will repeat this over and over in Stop and Go traffic so you can read the newspaper and play Sudoku while texting your boss.
Old 03-27-2018, 04:59 PM
  #34
raja777m's Avatar
2014 E350 4M Diamond Silver
1. Under 20mpg, no human intervention is required.
2. at stop and go traffic, if the car in front of you is stopped for more than 5 seconds, you need to accelerate to start the vehicle moving. But when ECO mode is active, and the engine is turned off during this stop, it'll start the vehicle(when the vehicle in front of you moves away) for you but will not move until you give some gas.
Old 03-28-2018, 12:26 PM
  #35
E250_92101's Avatar
According to the Owners Manual, DISTRONIC can only apply a maximum of 50% "braking force." In the crazy SoCal traffic, I've been cruising down I-5 with Distronic engaged with the my car following traffic at around 75-80 mph when the car in front started braking extremely heavily. At that point (and to my surprise!) Distronic disengaged and gave a warning sound. This meant that the braking power required exceeded Distronic's ability of 50% of available "braking power." At that point, I needed to brake manually. If you don't start braking manually in time or don't brake hard enough, the COLLISION PREVENTION ASSIST PLUS functionality kicks in. In other words, you'll get a second visual and audible warning (first was from Distronic disengaging). If the system determines that a collision is still likely to occur, then it will start braking autonomously.
In other words, the sequence can be this if the traffic stops suddenly while DISTRONIC is engaged: 1) Distronic disengages and warns the driver with a sound and visual warning. 2) Driver is supposed to manually break to prevent collision 3) If collision is still imminent, COLLISION PREVENTION ASSIST PLUS gives an audible and visual warning 4) If driver still fails to brake, autonomous braking will (hopefully!) be applied.
Here are the quotes from the manual (I have witnessed the first part, not the second part):
"DISTRONIC PLUS brakes your vehicle with up to 50% of the maximum possible deceleration. If this braking force is insufficient, DISTRONIC PLUS warns you visually and audibly. There is a risk of an accident. In such cases, apply the brakes yourself and try to take evasive action. "
"If COLLISION PREVENTION ASSIST PLUS detects that there is a risk of a collision, you will be warned visually and acoustically. If you do not react to the visual and audible collision warning, autonomous braking can be initiated in critical situations."
The following 2 users liked this post by E250_92101:
Exup99 (03-28-2018), TeeEl (01-08-2019)
Old 03-28-2018, 01:53 PM
  #36
kajtek1's Avatar
I remember seeing some suggestions in the past how to test Collision Assist Plus with cardboard boxes or such, but did anyone actually try to test it?
I see that system can be disadvantage. I drive often in heavy traffic and have to cut between the cars with small clearances. The system beeps on me quite often, but would hate to be surprised if it pushed brakes in such moment.
That did not happen so far, but what are the limits?
Old 03-28-2018, 11:47 PM
  #37
DFWdude's Avatar
Received 1,725 Likes on 1,105 Posts
2016 E350 Sport
Originally Posted by Pette25
2016
I have a 2016 without Distronic and mine works. You mention your car does not have bumper sensors. Mine has 6 in each bumper. But I also have Parktronic.
Dealer time, hopefully under warranty.
Old 01-08-2019, 07:43 AM
  #38
raja777m's Avatar
Meaning, the vehicle stops automatically with sudden cross traffic/carts/other objects? or that is only available in S-class?
Thanks.
Old 01-08-2019, 08:11 AM
  #39
raja777m's Avatar
delete delete
Old 01-08-2019, 09:44 AM
  #40
KEY08's Avatar
2014 E550-sold 😩
Thanks.
No. code 253 pertains to the audible warnings and braking assist that comes when there is danger ahead. It includes preparing the cabin for impact (seat belt tensioner system), etc. along with providing brake assistance and modulation while you press down on the pedal hard. It will provide enough stopping power to bring your car to a halt without stopping so quickly that the car following you ends up in your trunk. You will get pedestrian warnings, but must apply the brake.
Old 01-08-2019, 10:27 AM
  #41
raja777m's Avatar
Sorry I didn't get it, during cross-traffic the vehicle will come to a stop?
I had two people who intentionally drove by while I was reversing from a parking lot and the vehicle didn't stop automatically.
As you mentioned, it won't stop when people walk but just audible sounds. Which is intermittent and turns out the COMAND needs to be replaced (hopefully under warranty which is another story yet to come)
Old 01-08-2019, 10:43 AM
  #42
KEY08's Avatar
2014 E550-sold 😩
Hi Raja, Does your datacard show these options on your car? These deal with pedestrian warnings and cross traffic specifically on the E Class.
We don't need you involved in any more fender benders. LOL
268 - EXPANDED BRAKE ASSIST (BAS+)
269 - BRAKE ASSIST PLUS CROSS TRAFFIC (BAS+Q)
271 - AUTONOMOUS BRAKE INTERVENTION/WARN. FOR PED. PROT.
Old 01-08-2019, 10:51 AM
  #43
raja777m's Avatar
Yes they are available based on datamb.com
https://www.datamb.com/vin/1eQm3AV5yWW29GW6N
Old 01-08-2019, 10:54 AM
  #44
I believe that the rear-end collision system is actually referring to the long-range radar that scans for impending rear-end collisions. If you're about to be hit, the car will put on the brakes if you're stopped, and remove slack in the seatbelts, and prepare the cabin for impact. PRE-SAFE Brake, BAS Plus, Collision Prevention Assist Plus, and related systems will assist in forward collision events, including pedestrians, cross traffic, stopped vehicles, and moving vehicles, in certain conditions.
If you want the car to stop on its own in reverse due to cross traffic, that feature is only available in the W213 E-class and newer S-class. Just confirmed, unintentionally, that it works on my car but it works well!
raja777m (01-08-2019)
Old 01-08-2019, 11:11 AM
  #45
raja777m's Avatar
While I'm here discussing the Datacard, sorry to hijack the thread:\
881 REMOTE TRUNK LOCKING
Does it mean, the trunk lid should close by holding the trunk key on the remote? It never worked to CLOSE. But worked fine for opening it.
Thanks.
Old 01-08-2019, 11:15 AM
  #46
KEY08's Avatar
2014 E550-sold 😩
To the best of my knowledge there is no long range radar in the trunk/rear area of our vehicles, Raja. There is radar in the side fenders for the blind spot assist, but that is it. The only long range radar is the Distronic star in the front grill.
Old 01-08-2019, 11:22 AM
  #47
KEY08's Avatar
2014 E550-sold 😩
Thanks.
I believe you can use the foot swipe, switches on the trunk lid, the switch on the driver's door, and the fob to close the trunk. I have never used the fob to close the trunk, and will have to try it tonight to see if it will close the trunk. I know all of the other ways work. How many ways do we need to close the trunk lid?
Old 01-08-2019, 12:25 PM
  #48
Rogue Leader's Avatar
2014 Mercedes Benz E350 Sport 4matic
Holding the FOB key for trunk close works on both my 14 E350 and my wifes 17 GLE 350. All the other methods close the trunk too.
One of the things I love about Mercedes, the ergonomics of everything, literally every possible way you could intuitively think of to close and open the trunk, is available to you.
The following 2 users liked this post by Rogue Leader:
KEY08 (01-08-2019), raja777m (01-08-2019)
Old 01-08-2019, 08:51 PM
  #49
raja777m's Avatar
along with the keyfob, an app to start/stop and do these functions would be great. Okay, I'll stop day dreaming and save for future S-class.
Anyway, I just tested again and NO the Keyfob doesn't close the trunk.
Just being a bit too careful before my ELW ends July 2020. Oh boy, time flies super fast even with this slow E350. (Slowest of the bunch .
Old 01-09-2019, 01:57 PM
  #50
Thats weird.... why does it work on my car and not work on yours?
Quick Reply: Collision prevention assist
