Sponsored by: CARiD
Removed Windshield water tank due to a leak. Lost most radiator fluid!
Old Oct 24, 2017 | 01:11 PM
PerfumeFactory's Avatar
2011 E350 BluTec & 1984 300DT
Had the bumper, etc. off to replace cracked headlight unit -- deer collision -- and decided it was a good time to remove the also damaged, leaking windshield water tank. Before the end of the driveway, engine running, got a "Check Coolant..." warning & found it has lost most of its fluid! Severe surprise! I assume this is the winter heating arrangement. Anyone advise me on which hoses -- seems to be the two short ones near the bottom - and if I can simply patch them into each other with 1/4" pipe section and hose clamps so the 2011 E350 Diesel can be drive until tank replacement? Thank you.
Old Oct 24, 2017 | 01:38 PM
E250_92101's Avatar
2016 E250 BT, 2021 EQC 400
Can’t help you identify the hoses, but your plan to temporarily splice the coolant hoses together will be fine.
