So i looked around the forum. I thanks to the forum figured out how to lower the volume on for the nav. is there a way to deactivate it all together. Currently i hit the mute button every time it comes on?
2014 e550
2014 e550
I don't use the system, but if I recall you do have to mute it each time. Perhaps there is a setting deep in there but I don't recall seeing it.
You can vary the volume of the nav prompts by using the volume knob when there is an active prompt speaking. So if the radio is playing, then you only change that volume, but when its speaking at you, then you can lower it down and it will stay at that volume. I dont know if there is a way to mute it all together but maybe set it so low you dont hear it. HTH.
RA72825
close
- Join DateOct 2005
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:1,640 Times in 1,198 Posts
Maybe just use your phone map apps and avoid it all together. Other than adjusting the volume to its lowest setting, I don't believe there is a way to permanently mute the prompts.
Quote:
I have scoured all available resources and i think you are right there is no other way, Comand fail...Originally Posted by KEY08
Add it to the list of other nav fails for MB.
Quote:
2014 e550
Easiest way I found it hit the speak key and say "guidance instructions off"Originally Posted by al300sd
So i looked around the forum. I thanks to the forum figured out how to lower the volume on for the nav. is there a way to deactivate it all together. Currently i hit the mute button every time it comes on?2014 e550
Quote:
I think this does the same as if you press the mute button while it speaks. Guidance comes back at re-start.Originally Posted by wivenhoe
But there is almost perfect way to mute it, almost.
Go to NAVI settings and uncheck the Audio Fadeout, then when the instructions speak turn the volume all the way down. This sets the volume to almost mute and it does not lower the radio volume. If radio is loud enough it is hard to hear any of the instructions. And this stays for the re-start too, at least in my car it does.
tresean1
close
- Join DateMar 2011
- LocationVA
- Vehicle(s) I driveW212 E-class, W211 E-class, F10 5-Series
Liked:136 Times in 125 Posts
Thanks---I was looking for a way to do this, without having to mute it every you start the car. In the Bimmer, getting rid of navi audio stays that way forever until you re-enable it. I'll have to try your "trick" in the Benz.Originally Posted by Arrie
I think this does the same as if you press the mute button while it speaks. Guidance comes back at re-start.But there is almost perfect way to mute it, almost.
