Sponsored by: CARiD
AC Issues
Old Nov 19, 2017 | 01:45 PM
Kolton's Avatar
E550
AC Issues
Hi everyone, a few days ago I turned my AC and have not been able to turn it off since. The light on the button remains on as well as the actual air conditioner. I did some research but haven’t found anything helpful yet.
Has as anyone had or heard of this issues? I suspect a fuse might be blown but I have no idea where to even look for something like that. Thanks for any help you can provide.
Old Nov 19, 2017 | 08:11 PM
Oda112's Avatar
2010 W212 E550 4matic
If anything, a blown fuse would not allow it to be turned on so I don't think it's that. You might have a blower motor regulator or some other sort of automated controlling mechanism failure. If you're not familiar with how the system works it's best to take it to a specialist who has a STAR scanner and get it sorted. Also, you could try disconnecting the main battery for a few hours and then reconnecting it again, sometimes it helps if it's a computer related issue.
Old Nov 19, 2017 | 09:30 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
What happens when you turn climate off? And then turn on again using auto?
Old Nov 20, 2017 | 03:42 PM
Kolton's Avatar
E550
Thank you, I'm dropping it off at the dealership later this week, I was just hoping someone might have had this issue before and found a simple fix.
Old Nov 20, 2017 | 03:43 PM
Kolton's Avatar
E550
AC is still on. I've tried about everything I can from the inside of the car
Old Nov 20, 2017 | 08:13 PM
thefisch's Avatar
Top Answer: 1
Sounds like a stuck relay is it is always on, even if climate is off. Good idea to get it checked out.
Old Nov 20, 2017 | 10:45 PM
- Mover -'s Avatar
E550
Fuse #66 is supposed to be for the AC system.
Pull the fuse out. That should stop it. If not, fuse #12 is tied to the AC system as well based on the diagrams I came across.
