ABS,ESP and ESD error after wheel bearing replacement
Hi!!
Just replaced my front left wheel bearing, and after that i got ABS,ESP and ESD error.
Tried to erase the errors with a code reader with no luck.The error where erased but came back after i tried to drive.
The first i can think of is that is some grease lest on the ABS ring or sensor.
I cleaned the sensor with WD40 before i installed the hub, maybe i have broken the ABS sensor?
And i am not sure if i cleaned the ABS ring good enough and there are still some grease left on the ring, i dont know if that can make these errors.
Is it easy to remove the ABS Sensor?
Anyone have some tips?
