Sponsored by: CARiD
Led headlight problem
Old Dec 4, 2017 | 07:14 AM
yiannossavva's Avatar
Gcl 220d 2018
Hello
eny ideal with this errors?
thanks
Old Jan 15, 2018 | 09:20 AM
Gcl 220d 2018
I never get answers from the forum
Every time I need help no baby answer
Enyway I find the problem and share it
I change the big control unit, I buy a used so no reprogram needed
Hope this help other people here
Old Jan 15, 2018 | 09:19 PM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
It would be helpful for you to describe your problem. Having the DTC's (error codes) is helpful, but not without knowing what the problem is from your point of view.
Old Jan 16, 2018 | 06:42 AM
Lorenzo's Avatar
2001 CLK320
which control unit did you change out
Old Jan 16, 2018 | 03:20 PM
belarus27's Avatar
2010 e550 p2
most likely the one that connects to headlight , the ballast , im not sure if its called the same on the LED headlights tho.. just a guess
Old Feb 15, 2018 | 02:41 PM
Gcl 220d 2018
Problem solved. I change the big control unit under the headlight. The control unit need programming after installation
