intake mannifold
Anywhere from $100-$2000 depending on what you do. It's usually the lever that's broken. You can either buy just the lever and replace the lever which would be more in the $100 range. But it's usually a sign that you will need a new intake anyway and others warn that just replacing the lever might still eventually lead to problems where parts of the intake break off and does engine damage. Pierburg makes the OEM replacement and you can buy a new intake for around $455 which is the way to go if you're going to keep the car for a few years, you could probably find an indy mechanic who could put it in cheaper than the dealer. The dealer will probably want $2000 as the OEM MB intake is about $800 and with labor it may be pushed up to $2000.
I say this because they did on my car... I had a P2006 OBD-II code that kept causing my CEL to come on...
"P2006: Diagnosis of tumble flap 'Intake Manifold': Open circuit of sensor lines/Tumble flap shafts stuck in the nonactivated position" (equivalent to Mercedes Benz Diagnostic Trouble Code 0522).
And yes, I do agree with the remaining portion of your post; I ended up replacing the entire intake manifold rather than just use a kit to repair the tumble flap actuating rods. You will have to remove the intake manifold (a task that is very labor intensive) to properly replace the actuator rods... And to do so only to then most likely have to repeat a couple of months later simply because another part happened to break or fail... Might as well put in a new intake manifold (you can find OEM intakes for as low as $450-$500).
For what its worth, there are 2 additional codes that are also related to 2 more intake manifold tumble flap issues:
- P2004: Diagnosis of tumble flap 'Intake manifold': Short circuit to ground of sensor lines / Tumble flap shafts stuck in the actuated position. (equivalent to Mercedes Benz Diagnostic Trouble Code 0521)
- P2005: Diagnosis of tumble flap 'Intake manifold': Short or open circuit in sensor lines / Mechanical fault of one actuating lever / Sensor faulty, replace the sensor. (equivalent to Mercedes Benz Diagnostic Trouble Code 0524).
I would contact the dealer who did the diagnosis and ask them for a list of OBD-II codes or diagnostic trouble codes that they read from ECU... Knowing those codes would help make a more educated guess as to how much a repair job will cost.
