Left Front Airmatic Suspension Knocking
I have not been able to find a source online for replacement front shocks for this car. Rear ones are easy to find, but front ones are impossible. Even Arnott doesn't have them. Is this a dealer only item?
Thanks for your help!
MB recommends replacing to current part # in pairs if mileage is 50,000 >.
“Since it can be assumed that a new Airmatic/ADS suspension strut installed in a high mileage vehicle, would not match with the used suspension strut and thus impair ride comfort and or vehicle dynamics, it is then recommended that these components be replaced in pairs only after the vehicle has reached a mileage of at least 50,000 miles (~ 80,000 km). In the cases where a strut may have been previously replaced, the mileage differential between struts must be at least 50,000 miles (~ 80,000 km) in order to replace in pairs.”
Attached bulletin references previous models nevertheless, same principle applies. Not sure how far out of EW you are or mileage when passenger side was replaced, possibly a discussion with service manager is in order.
As for the front shocks, unfortunately, only the dealers have them. Apparently there's not enough demand for them, they don't break as often as the rear ones. They will probably start making them in the future, but for now we're stuck with OE as replacement parts.
I thank you for the response.
Michael
I found out from dealership that it's a $1058.00 part!
