Sponsored by: CARiD
Blower working intermittently
Old Dec 26, 2017 | 09:07 AM
MattsE350's Avatar
2010 Mercedes E350 4matic
Hello,
I am having issues with my blower motor working intermittently. It usually takes a hard bump to get it to start working. Does anyone know of any easy fixes I can try before replacing the entire motor? I have looked around for a fuse panel diagram and relay diagram for my car and can’t find anything. I was going to check the relay first to see if it is going bad and then I was going to try the regulator/resistor. If anyone can give me any advice I would be greatly appreciative. Thank you.
Matt
2010 E350 4matic W212
Old Dec 26, 2017 | 09:19 AM
s140s's Avatar
2013 E350 4Matic
If hitting a bump only starts its then most likely the brushes are worn out. You will probably need new blower. ~$140
https://www.fcpeuro.com/products/mer...tor-2128200708
File Type: pdf
Old Dec 26, 2017 | 10:51 AM
Mud's Avatar
Mud
2011 E-350 4Matic Sport
Its also possible the connector is not making complete contact. Seems over time either the contacts loosen or have a bit of corrosion buildup. Similar has happened to several here including me with back up camera. Sometimes unplugging and replugging connector a few times can clean off the terminals and you're back in business. At least you can give it a try to see if it helps.
Old Dec 26, 2017 | 06:00 PM
djdirty76's Avatar
2014 e550
Hi. I had same exact issue like 3 weeks ago. Check connector first. For me it was the loose connector. It wasn't plugged inn properly. I pushed it inn and so far so good..
Old Dec 27, 2017 | 12:02 PM
MBNUT1's Avatar
2010 E350 4Matic
Blower replacements are common on this model. Given the posts above it would be interesting if they were due in large part tot he connectors.
