aux battery malfunction
I prize MB for actually thinking for the owners and on lot of instances - protecting cars from owners stupidity.
So if the warning comes in yellow, that means you can continue to drive for now. Sometimes the message will tell you for how long.
But if the warning changes to red warning, be ready to immediately pull over and turn the engine off.
If you ignore that, the car can do it for you and that seldom is pleasant.
If you have a 2013 or later then it is for the eco start/stop feature. Different location and a much more expensive battery.
https://www.ebay.com/itm/Mercedes-Be...item1c8dd34a0f
change battery is very easily, dealer will charge you for diagnostic, remove panel B, remove panel C, unpack battery, disconnect battery, install battery, battery disposal, reset here and there, etc, etc, not to mention have the car for 4 hours !
