Sponsored by: CARiD
Steering wheel not coming down
Old Jan 3, 2018 | 12:00 AM
chrisvr6's Avatar
lexus gx470
Anyone have this problem. Goes in and out, up also just not down. Seems only when its really cold out. Otherwise it works.
Old Jan 3, 2018 | 01:43 AM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
yep!! i have same issue.
Old Jan 3, 2018 | 01:30 PM
Jabberwock's Avatar
Eclass
I had this a couple of times, although not temp dependent, column was replaced under warranty for a creaking issue while turning and the adjustment issue hasn't returned,
Old Jan 3, 2018 | 06:05 PM
jylee's Avatar
14 E350; 12 Camaro; 07 Range Rocer; 06 Dodge Ram
There is a SW update on the tilt wheel programming.
Old Jan 3, 2018 | 06:31 PM
cocobeex's Avatar
Thanks for the info.
I will double check with service center.
Old Jan 9, 2018 | 01:59 PM
pschiller's Avatar
2013 GLK350 & 2013 E350
I had this problem - I "fixed" it by going into he menu and turning off the easy entry function and then turning it back on.
Old Jan 9, 2018 | 02:10 PM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
I have this issue, if I play around with it (use the little dongle and move the wheel up/down a # of times) it will eventually start working again for a few weeks before doing the same thing. Trying to make it break again so I can take it in for them to check it out.
