265 will fit on front, at least if you have Airmatic because that is what I have on my fronts. My offset is either 45 or 46mm and I have no rubbing. The tire on the inside is about 1-2mm away from the shock though.
I see that you have 4Matic, which may be an issue as the front shocks are different.
i do not have airmatic, but anyways i am going a different route found a very good set of Vossens CV3-R with tires for $1000 great condition
5x112
front tire 245/30/20
20x9
back tire 295/25/20
20x10
i use to have 275 in the back and i was good so hopefully the 295 will not rub in the back
OP, 265/30-19 is an incorrect tire for W212 - wrong diameter (too small) and wrong load. 265/35-19 is the correct tire, but will rub in most cases upfront. For 9.5" wide wheel, 255 (/35 for 19") is the widest tire to be safely used upfront.
just heard back of the guy whos selling the vosses, they are 20x10 front with 245/30/20 and 20x11.5 in back with 295/25/20 im guessing these are too big for my w212 4mattic
I heard you can fit 300mm wide tires on the rear axle on those cars, but this is stretching the car design.
Depends on offset you might need to roll the fenders.
