Sponsored by: CARiD
A/C vent temp differences
Old Jul 10, 2018 | 06:56 AM
Eddot's Avatar
2015 S550 Executive, 2017 Volvo XC60 R design, 2009 BMW Z4 35i DCT TwinTurbo
Has any one noticed a temperature difference between the center vents and the right side passenger vent. With A/C running, no matter how I have it set, normal or recirculate, the temp out of the passenger right vent is not as cold, measured over 5 to 8 degree warmer. A/C set at 68 deg, center and left temp will be 55 deg and right will show 60/62 deg. Air volume is the same all around so not a blockage problem. This is the same when in a shaded garage or out in the open. Any thoughts.
Old Jul 15, 2018 | 11:11 AM
aca03mk's Avatar
E220
My passenger side and driver side vents blow two different temperature air. One is quite hot and other slightly colder - irrelevant of the actual temperature.
Did you find a solution?
Old Jul 15, 2018 | 03:33 PM
Eddot's Avatar
Thanks for your reply, I just had a chance to ride with a friend who has a '14 E sedan and his A/C seems about the same, not as cold thru the passenger vent as the others. Must be an MB thing. Seeing Dealer next week for my smell issue I poster earlier, seems to me to be exhaust or some sort of gasket leak thats causing this. Will ask about A/C temp then.
Old Jul 15, 2018 | 04:04 PM
aca03mk's Avatar
E220
You may want to search my screen name on B***World to see the answer to the same question. Apparently it could be a duovalve or needs measurements read off the car.
Old Jul 17, 2018 | 07:01 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
http://www.mercedesmedic.com/ac-air-...le-codes-list/
This is the best AC troubleshooting page there is, so vote it for stickies as I am getting tired of posting the same link hundred of times on forums.
When W212 doesn't allow for reading the sensor values on the dashboard (at least I did not find it) - all other principals are the same on MB for last 20 years.
So find a scanner who can read the sensors and if you don't know how to interpret them - post them here. Read the notes at bottom of the page for better instruction.
