Sponsored by: CARiD
Aux Battery Replacement for 2014 E350
Old Jul 11, 2018 | 09:03 PM
johnlit's Avatar
2014 E350 4MATIC
Aux Battery malfunction on my 2014 E350 4MATIC. Where do you buy one? Is it easy to replace? Any programming required?
Old Jul 12, 2018 | 01:31 AM
LALALAND's Avatar
E350
Group Size AUX14 AGM Minimum Cold Cranking Amps170 (i think my original battery has it as 200 amps) You can buy from autozone, advance autoparts, kragen auto parts, mb dealer, napa, etc.
Tool:You need a 10mm socket for the 3 screws. I follow this video when I recharge aux battery with my Ctek charger every 5-6 months. Very easy to remove and install as only 3 screws to remove/tighten, 1 hose to detach/attach, and cage to lift.
I don't think there is a memory unlike the main battery. Didn't drive while i had the aux battery removed from the car to test it out.
Old Oct 21, 2019 | 08:47 PM
SeanTran's Avatar
E350
can you re-post the video on how to replace the auxiliary battery on the 2014 E350? Mine needs to be replace.
https://www.youtube.com/watch?v=zdHR8rTW_R4
Old Oct 22, 2019 | 08:55 AM
konigstiger's Avatar
'71 Pinto
See attachment.
File Type: pdf
