Not your average wheel speed sensor issue
At first I only got this warning after taking a hard turn and giving it a bunch of gas. but after the below work it comes up almost right away.
I replaced the lower right control arm (was bent pretty bad) Now the steering wheel is off about 30 degs. to the right (alignment scheduled for Tuesday)
I also had to replace the front right brake pad wear sensor.
I replaced the bearing and races on both front wheel hubs because they were starting to whine.
*The front right turn signal sometimes doesn't work, still haven't fixed this.
After doing the above work, I get the ABS,lane keep, etc warning and the below code, I replaced the sensor (pins and connector looked good on both ends) but it still gives these errors, even when just sitting there and not moving. You can also see that the right speed senor sometimes drops below like its missing the signal.
My problem is the ABS sensor connector goes behind the metal wheel well and I have no idea where from there, so I can't tell what the next connection looks like as far as corrosion goes. Anyone have any ideas? Do you all think the alignment will help? I tried the wheel angle reset and it didn't work.
If the alignment doesn't help I'm going to tear into the steering column and clean the steering angle sensor.
It should be known that I think the car had an accident in the front right corner.
Next step is redo the graph and see if I loose all signal from the wheel speed sensor. If not Im 100% lost.
I did some more research and bugged a few others in the forum and found that aftermarket wheel hub oil seals might not have a strong enough magnetic presence to operate the wheel speed sensor correctly. Went to Mercedes Benz, bought two new seals and grease, replaced them and still have the same exact issue. (haven't driven it around enough to know if the speedo is going to stop working.) *I also took the liner of the wheel well off and found another ground point, I wire brushed the connections and bolt, also looked at the cam plug going into the ?ECU? (everything looked clean and straight). and I'm still get the errors.
Can anyone recommend a good shop in the Dallas / Fort Worth Area? I'm afraid if I take it to MB they will just charge me a lot of money to replace the sensor, which I have already done.
Its a shame, I really liked this car but have completely fell out of love with it.
I've had other high performance cars that didn't have half the issues this car has had. Is that normal for Mercedes?
You have bad wheels speed sensor and you fix it by alignment?
Unless I missed it, you did not replace the faulty sensor?
Than how can seal affect the sensor? Did you inspect reluctor rings?
As far as the reluctor ring goes, It is my understanding that the sensor reads the oil seal? there is nothing in the FRONT wheel hub itself, just seal and two bearings. The rear has a reluctor ring but not the front, right?
Case closed.
Just a note that sometimes a continuity issue between the sensor and the abs module , either in wiring or connector can cause the error code despite sensor replacement.
Also, if I understand correctly, the steering wheel position can throw the abs code, as the wheel sensors are reading straight line (all wheels number of turns the same) but the steering wheel angle sensors are reading turning. If the difference is out of program parameters = CEL.
I hope that your troubles are over with this though.
