E550 fuel tank removal ( 2013 )
Good luck,
Bob
Thanks for the
mercy-me
Thanks for the attachment I took out the inner wheel well and saw the bad news.
Poor design , I might just the cut the filler and evap tubes and splice with silicon host
According to ASRA times, to R&I (Remove & Install) the fuel tank is 6.3 Hrs. This includes the R&I of the complete rear axle assembly. The rear axle alone R&I is 4.3 Hrs. These would be rates that the factory would pay for a warranty situation to the dealership. Since this is not a warranty job for the dealership, I would expect them to mark it up considerably perhaps 3-5 Hrs more. Going a step future, the tank part 212 470 75 01 is another $992.20 from MBpartsdirect. If you can get by with paying your $1k deductible for a new tank install then that might be a good way to go. I would still consider a good patch repair as a viable alternative if done properly by an expert. Repairing plastic does not involve any welding so just normal gasoline safety precautions would apply.
Anyway,
Good luck,
Bob
