Battery Issue, part two
One employee told me that letting the car run in idle (parked) will do nothing to recharge the battery, no matter how long you let it run. It can only be recharged if you drive for 20 miles or more as the alternator does not work in idle. 20 miles results in a full charge.
Another employee said that letting it run for two hours after jump starting will result in a good charge.
Who do you believe? Both were in the service department.
There was a post a while back on the variable charging logic for the W212 that in a nutshell showed that the car decides what output is needed from the alternator based on a number of factors. It isn't one size fits all. I would only trust my Ctek charger and multimeter to verify.
