Sponsored by: CARiD
Tire light
Old Oct 5, 2018 | 11:42 AM
padrola's Avatar
2012 E350, BluTec
Tire light
Tire pressure is the same rear: 40, front: 37; but tire light went on and the left rear reads 40 as does the right rear; but the light is yellow and says check tire pressure?
Old Oct 5, 2018 | 12:40 PM
raja777m's Avatar
2014 E350 4M Diamond Silver
probably the spare tire in the trunk?
Old Oct 5, 2018 | 02:17 PM
Max_1's Avatar
2016 E350 4matic
It could be due to the setting of the "reference" values. I seem to remember you can reset it in the tire service menu. I have seen the option a while back but probably will not be able to find it off the bat.
For example if it was set 39psi front and 44psi rear that your current values are too low.
Old Oct 5, 2018 | 02:47 PM
RA72825's Avatar
Yes, just open up the Tyre pressure in your dash display and click the down arrow. Accept the new pressures and be on your way.
If you want to adjust pressures do it first then accept the new pressures and you are on your way.
