Sponsored by: CARiD
2007 e550 Airmatic Front issues
Old Nov 16, 2018 | 02:30 PM
Martin Smith's Avatar
e550
Hello,
I have 07 e550 last year replaced both front struts and compressor, diver side had hole in air bag and compressor piston froze. Car was fine until month ago. Front end on ground red warning light on dash. Compressor runs and pumps air, have new air block( when replacing there was air in the supply tank line took min to run out when line opened. if car is jacked up I can hear the relays on the front struts clicking to adjust pressure. Compressor relay works when air block replaced compressor worked again when car started to fill supply tank. no air getting into the struts. Help I do not have Star software for this model only for older car..I do not hear any leaks but also no air coming out of strut lines when fitting opened What am I missing? I'm in Central Coast Ca if anyone has STAR around that could check it , car on ground hard to move now. TIA Martin
Old Nov 16, 2018 | 10:52 PM
Garagebuilt's Avatar
Porsche 993
Probably get a better response from the right sub forum.
