Knock or pop noise from front end
The noise is a kind of knock/pop noise for instance if I’m parked up and pull off and then touch the brakes it will make the noise. If I then reverse and then tap the brake it again dose the noise. It’s not a constant noise only when pulling up or reversing etc.
ive taken all wheels off and checked brakes and arms etc and can’t seen anything wrong. I’ve had my father in law listen while on the drive going back and fore and he says it’s definitely front end noise but can’t pin point it.
In the last few months I’ve replaced all discs and pads using ATE and the rear suspension air bags not sure if anything is related
If anyone has had this issue previously could you please comment to save me taking it to a garage
Thank you
You mentioned recently replacing the brake components. It sounds exactly like it’s your pads just adjusting to the new direction you’re traveling in. Some very minor slack in the area where the pads are hanging/mounted to the caliper. If I am correct, then you have nothing to worry about as it happens to many cars after new pads have been installed. My Toyota, VW and my MB all do this as all have received new OE pads and rotors over the past year.
Annoying a little, yes. But not a major problem.
PS, not sure where you live, but cold air will exaggerate this a little more as the metal contracts. In hot/humid summer, likely not an issue.
I've been to. Mercedes today and purchased new pads and fitted them and it's exactly the same
£70 wasted It's such a loud annoying noise and I know it shouldn't do it which makes it worse I dread having to reverse into spaces due to the noise.
I think I'll have to take it into a Mercedes specialist to take a look
Thanks again mate
Your brakes may look like this. Inner pad has a clip that fits into the piston, outer pad has a spring clip to provide tension.
The caliper mounting brackets themselves have some stainless steel insert clips as well that fit into the rail where the pad ears sit - do your mounting brackets have all new clips? Those clips are designed to cushion the pads as they want to move around.
Another source of noise (besides loose caliper mount bracket bolts that I doubt you have) are the slide pins. If they are very worn, the entire caliper can rock back and forth depending on wheel direction.
noticed next morning when i started backing out from garage , i heard like a thump/pop/knock. I could pinpoint it was the driver side. Found time to check and lubricate everything and also bent the metal brackets.
and the sound was gone. So im sure in my case it was the brackets. When i had them off i bent them in a little.
end of story
