Sponsored by: CARiD
C250 CGI 2009
Old Dec 17, 2018 | 01:42 PM
Mwanakache's Avatar
c250 CGI 2009
C250 CGI 2009
I just changed break pads behind and did service. After that am hearing some vibrations at low speed to high speed. What could be the problem?
Old Dec 17, 2018 | 01:50 PM
RA72825's Avatar
Not sure how you hear a vibration, but do you feel something vibrating? Are your brakes vibrating under use now? Is your car vibrating at slow and high speed without being under braking? Did you torque the lug bolts? Do you have aftermarket wheels? Did you replace rotors also? Did you use an OEM pad? Did you bed the new pads? What pressure are you running in your tires? How many miles on your tires? Have you hit any potholes lately? Is your steering wheel straight?
Old Dec 17, 2018 | 02:03 PM
Mwanakache's Avatar
c250 CGI 2009
The car is vibrating under low speed or when it's just starting at low speed without braking.
Old Dec 17, 2018 | 02:11 PM
RA72825's Avatar
Motor mounts
