Chirp noise in drive belt area - 2011 E350
Here's the video
https://www.fcpeuro.com/products/mer...-272273beltkt1
https://www.fcpeuro.com/products/mer...-4834100d#desc
If you are frugal - you can pop off the belt (via the tensioner) and then you can spin by hand the 3 pulleys - if they roll smooth like butter - they are most likely good - if they rattle - then there is your problem..
I had one bad pulley and that is how I found it, it was the cheaper $35 pulley that was bad. Most dealers will have those in stock as well as aftermarket stores...
(maybe good time to replace the belt if not frugal too LOL)
Cheers
JPC
