2014 W212 Tail Lights Problem
Hello everyone, my car's right outside tail lights is not working. (Brake, signal and reverse lights are ok). Before, sometimes it used to be has problem but when I restarted the car then it was working. But now it never works.
When I hit the tail lights it starts to work but after a short while again it stops to work. Here is the video link about it and also I share my own car's photos. Is anyone having this problem? And also does anyone know the solution? Thanks for your answers and helps. https://cimg4.ibsrv.net/gimg/www.mbw...145c6b6cdf.jpg https://cimg6.ibsrv.net/gimg/www.mbw...060e0a1e21.jpg https://cimg7.ibsrv.net/gimg/www.mbw...d0fc094b5.jpeg |
https://mbworld.org/forums/e-class-w...2014-e350.html just replace the light. It’s cheap; less than $250 |
Originally Posted by KEY08
(Post 7653440)
Mercedes E class Rear Light flicking
Hi I know a guy in the midlands UK- exchanges the light for u...
£75 I paid his number - 07946661234 |
Hello from Portugal. I have the same problem. It started with one light (a few weeks ago) and now both rear lights have the same default. I think the problem is not with the light, but something else related to the electrical part of the car.
Thanks very much! I will try to find out someone to deal with it.
Hello,
Resurrecting this thread because my taillight just started with this intermittent foolishness. If I smack it, it lights; then sometime later goes out again, just like the original poster. Anyone find a fix for this yet, or at least a way to check for failure? TIA! :) Edward |
So nobody else with this taillight issue??
Edward |
Originally Posted by Edward993
(Post 8816609)
Edward Either replace or repair the bad unit then consider the opposite side to fix the same excellent feature. |
Ok, good to know. So perhaps re-solder the poor solder joints. I solder well, so perhaps this is the simple fix?
Edward |
A broken solder joint, several YouTube videos on how to fix. I would desolder all joints with leaded solder because lead-free solder is brittle anyway. This is why modules in all cars, not just our beloved Mercedes, fail so often.
