Need help with a new to me 2011 E550
I susoect an air leak in one or both front airmatic struts/shocks. The car seems to drive OK but this morning after leaving the car n sport mode when we started it we got a message to wait for the car to rise. After letting it rise I switched the car to comf mode assuming that’s a higher setting and thinking I t takes longer to leak the air.
Assuming that im going to need to replace the air struts is Arnott the place people are going for them? If not, what’s the best place to get them from? Also is this a pretty simple replacement to do? I did the rear suspension in my E320 1999 including the knuckle bushings.
Also I seem to have an issue with with the dynamic seat control, the first button which is supposed to move the seat cushion front and back it does nothing but I think I hear a faint tap when I push one direction. Also the next selector pulls I. The bolsters in the back of the seat but when I release it doesnt stay inflated. Dynamic response setting seems to work as does the massage pulse. Thoughts? I checked the fuse number 60 in the trunk and it looks fine. Looks like the seat functions work from a pump but I don’t know if the lateral seat movement works off a pump. I’m guessing that the bolsters are electric and which would explain why they work if another feature doesn’t but I don’t have another car to compare to.
If you want to go down the Arnott road so be it but remember you will probably have to disclose that the AIRMATIC was disabled and converted. If you sell or trade and could take a hit on resale value. I won't make a recommendation either way just information to marinate on.
do you have a 550 yourself? If so does your car lower at all when you park it overnight or is that the telltale sign of a car that has a slow leak ?
Arnott rebuilds the air suspension shocks for your use in replacing failed units. There are some videos of W211 replacement online. W212 is similar and not difficult. Before you go down this road, get a diagnostic of The Airmatic performance in your car. There are so many issues that can cause the car to drop I cannot list them all.
wrong. Where did this information come from?
fwiw I spoke to someone at Arnott industries today in technical support about the car and about the suspension in general. He told me that at this time they don’t do the airmatic struts for the rear wheel drive W212 but they plan to release and expand their product line a lot this year so I am on their newsletter.
I’m now thinking that I do not have a leak in my aromatic system. When I bought the car two front tires were bad and the previous owner also replaced only one of the rear tires so he must’ve gotten a flat and didn’t want to put any money into it so we only replaced one. Now that I have two tires that are equal on the back and two brand new tires in the front everything seems to drive really well. The air Maddock system there’s a different feel than driving a car like my E3 20 which was a lot more mushy and especially when the car is cold the suspension feels pretty stiff so it’s just a different feeling ride for sure.
That’s good advice about getting a diagnostic. Sounds like a dealer only option right?
Point is that airmatic is covering up small leaks and will not notify the driver till the issue becomes catastrophic.
Get a scanner who can read airmatic (several of them starting $150) and check pressure holding.
If you drive like that, you are putting the compressor on overtime, so at the end you will have to replace bags AND compressor.
Give the car and you some time to get acquainted before getting too excited about potential problems.
