Wheel alignment needed with tire change?
I brought my car (2014 E350 sport) to the dealership last month to get an issue with the battery checked out, and they said all the tires were low on tread and one was almost completely bald. They quoted $295 per tire, so i went to Discount Tire instead and got 4 Barum Bravuris with 40K mile warranty for $406 installed.
My question is.....do i need to get a wheel alignment done? The dealer had recommended it along with tire replacement, but it is really necessary? The car drives fine, steering does not pull or anything like that. Just want to make sure it's not needed for proper tire wear, or anything like that.
Any help will be appreciated.
G
If you are getting the...new tires what's another $150 ..... Even with the $150 alignment and new shoes you are still less than half the dealer cost. Definitely recommend alignment as a base. Of Course dealers are going to recommend it. I would get alignment and if able would be a good deal to get both tires and alignment at same time.
Another question: Are they just telling you its bald or did they show you in person. Always ask to see while still on the lift...….keep them honest....Especially Dealers!!
The dealer is pretty much the most expensive place that you can have an alignment done. If you are concerned, find a good local indy garage familiar with MB/European and use them. In my case, I did just get an alignment done after installing camber bolt kits, the indy was $95, dealer would have been $180. I think others here may have used Firestone or similar chains, but I don't like the way the locals here treat vehicles. Might be better in other areas.
MB is always pushing alignments and as has been said there are plenty of shops that can beat them at price.
Yes that is correct OEM there is only front and rear Toe directional adjustment.
No Camber or Caster to adjust tire contact angles to fix it right the 1st time. Resolving costly, premature edge tire wear.
Fluted bolts only provide 1/8 inch (0.3 of one degree) change. Only available for front and inaccurate having one offset position.
We saw the need therefore to re-instate from the early 90's full front Camber and Caster, Rear Camber (and extra Toe). Providing up to "4 times" the adjustment range of the fluted bolts.
The K-MAC unique patented design replaces the 4 front and 4 rear highest wearing bushings at the same time.
Is precise single wrench adjustable. Accurately (under load) direct on alignment rack.
Catering for other than showroom height conditions - day to day commuting encountering high cambered roads, fitting of wide profile tires / wheels, altered height through load carrying or lowering. Correctly resolving steering pull. Ongoing adjustment for curb knock damage.
Front Camber and Caster Adjuster kit #502916 K $480
Rear Camber (extra Toe) kit #502226 K $480
Delivery $30 Worldwide $20 each additional kit
PayPal, Visa, M/Card
