spare tire compatability
A colleague of mine helped her daughter out when her Hyundai with a flat tire didn't have a spare by putting the spare from her Toyota on it. And it worked. Her tire shop said it would be fine if the tire size was comparable and bolt pattern matched.
I had never thought that you could use a spare from a different make/model but I guess it is possible if the rim is large enough to clear the calipers, the bolt pattern lines up, and the wheel circumference is close enough. This got me thinking that maybe I should be keeping spare tire kits if I am trading in a car. Apparently a car not having a spare is a thing now.
Anyone ever recycle a spare to use with a car that didn't come with one due to run flats or cost cutting? How would you go about verifying compatibility beforehand?
Driving long stretches on desert without spare is not my idea of confidence.
Lot of manufacturers use the same bolt pattern and I see often wheels from Audi, Tesla, VW swapped with MB.
The only issue might be rpm aka rolling diameter, but worse come to worse, you can always turn ESP off.
That said, I am in big favor of full size spare. Had to drive on donut spare years ago for 100 miles and that was not good memory
I have found websites that let you compare tire sizes. I assume that a small difference in rolling diameter of less than 1% will work. Maybe more variance will still work?
But will a 5 bolt donut spare from an MB fit another car also with 5 bolt wheels? Not sure if all 5 bolt are compatible, like using a donut from a MB on a Hyundia or Honda? I haven't found an updated online resource for bolt patterns using Google.
So if you luck out finding one on JY sure go for it.
The W211 wheel, that fits W212 is 155/70 R17 size. On my E250BT even 16" wheel will fit, but big V8 cars might have bigger brakes.
The only good thing about donut is that when I pack up my trunk, it will fit in rear legroom behind front seat. Full size will not do it, unless you push front seat forward.
Than life is about compromises.
