Sponsored by: CARiD
20" wheel questions.. yup another.
Old Mar 21, 2019 | 03:02 PM
93srvman's Avatar
2016 E550, 2018 GTC
First off apologies for yet another wheel thread, but I've about gone cross eyed scraping through for forums for who's running what setup, with these and those options differing and coming into play. Dropping a bunch of collected data on a few sheets and seeing it still all varies quite a bit.
So here's my predicament:
I have a 2016 E550 4matic with Airmatic suspension (stock height). I thought I had the tires somewhat narrowed down, but then to find out the tires I want (Continental DWS06) don't come in those sizes - aargh.
I'm looking at getting 20" rims in a staggerd config, here's all that's offered in 20's:
255/50ZR20 109Y XL 15500220000
245/45ZR20 103Y XL 15500190000
255/45ZR20 105Y XL 15500210000
265/45ZR20 104Y SL 15500240000
275/45ZR20 110W XL 15500280000
295/45ZR20 114W XL 15507940000
245/40ZR20 99Y XL 15500180000
275/40ZR20 106Y XL 15500270000
295/40ZR20 110W XL 15500300000
245/35ZR20 95Y XL 15500170000
255/35ZR20 97W XL 15500200000
265/35ZR20 99Y XL 15500230000
275/35ZR20 102Y XL 15500260000
315/35ZR20 110Y XL 15500310000
275/30ZR20 97Y XL 15500250000
285/30ZR20 99W XL 15500290000
Thinking the 245-35-20 front and 285-30-20 rear. Why? The spec revs are very close to each other 775:778 F:R, and the overall diameter is within .1" which should keep the 4matic happy. It'll give me a little more rubber as well vs some of the more common setups. The downside is there'll be a decent difference on the speedo where a 60mph reading will actually be 62.X mph.
Thoughts? Opinions? Offsets on the rims I'll NEED to go min in your experiences?
Old Mar 24, 2019 | 04:30 PM
93srvman's Avatar
2016 E550, 2018 GTC
Decided against this size when another member here has reported rubbing. I'll update when my purchase is finalized and installed but it looks like 245/30/20 Fronts and 285/25/20 Rears for now.
Old Jul 5, 2019 | 02:05 PM
93srvman's Avatar
2016 E550, 2018 GTC
Update: The rims and tires are on and I've put over 1000 miles on them. I was expecting the ride to be a lot worse but it's not bad at all, especially when in comfort mode.
2016 E550 4MATIC
The setup Vossen CVT in Bronze
F: 20x9" + 32 w/ 245-35-20
R: 20x10" +45 w/285-30-20
Here is the day of the install
And this is after lowering the car a little using air links.
I had the bags in the rear bottomed out (no tire visible at all) due to an install issue with the air links. The only rubbing was the tire on the inner wheel well, it cleared the fender lip completely. So the tire and offset combo is a good one.
