Jack Stand Options
Shuffle puzzle garage. Kinda cool how many cars you can place in the garage.
The mountain range in the background is nice!
Plus it took me a moment to "get the pun" with the California license plate...
It is ingenious design, where you attach the brackets/casters to posts with pins and then you lower the lift floor, who's weight will cantilever posts off the ground.
Lift is 7' tall, so goes under garage door just fine.
Having it roll-able made for several uses, like when I brought 3000 lb garden sculptures and had to unload them fast for trailer return. I raised the floor 1/2 way up, pushed the trailer under, strap the sculptures to lift floor and lifted it all to drive trailer away.
BTW having truck & trailer, I picked up the lift at local warehouse for $200 easy discount.
The only sad truth is that when you are DIY hobbyist 900 sq-ft garage is just too small.
https://www.sears.com/craftsman-prof...p-00950163000P
https://www.sears.com/ac-delco-2-ton...p-00950193000P
Or pick up a set for $40.
https://www.sears.com/ac-delco-2-ton-floor-jack-and-jack/p-010W006244419001P
I replaced pretty complex OM642 engine using 4-post and never had a desire for 2-post lift.
IMHO 2-post is good for tire/brake shop and that's about it.
Then you need to rely on the proper fastener installation so they do not pull out under load. Not my cup of tea and a project I would only hire out, so I had someone to sue if it all went to hell.
I'm an architect and have some experience with observing poor installations of many such things. 4 Post reduces that stress on the slab considerably.
If they crack under "their own weight" what you can expect from anchors under big stress?
Main problem with the industry is that concrete contractor are not using vibration for slab pouring. Such concrete will never have good consistency.
Read instructions they tell you when installing (drilling and tightening anchors) if slab is acceptable.
very interesting reads - I read 3 or so manufacturers instructions.
I will say if anyone is worried contact a local civil engineer or concrete supplier for them to review.
Drilling hole somewhere to find thickness is not a big deal.
Concrete supplier can be a lady with 2-weeks sale training.
Engineer will not drill, nor test your concrete.
You'd have to hire sample drilling Co, and send the chunks to lab.
Still even if you manage to install 2-post lift safely, why run all the hassle only to increase risk, while loosing portability?
4-post lifts are cheaper, although between Chinese and Mexican manufacturers, it is hard to compare the value.
My Chinese lift had couple of assemble flaws, with 1 potential for disaster, but nothing I could not fix in couple of hr spend on reassemble.
I am not worried about garage as it was designed to house a race car trailer and tractor truck
I am an engineer ... and do know the industry around where I live as I use them.
Our concrete companies have techs on staff as they come to sites to take samples and test in their labs.
I do not have a post tension slab
Our local Civil engineers come out and would check slab for thickness for a fee of course.
Different state different laws and industry practices.
I saw your review of the lift and cable rubbing hydraulic fitting... Well done review ..
Crappy design to me so I am leary of that brand...
Also notice they tend to be damaged a lot in shipping.
so on to more research
Quick story- I had a project in the lower level of the Museum Of Science and Industry here in Chicago and we had to saw cut the concrete floor for extensive new under slab plumbing. We assumed we would find a 5-6 inch slab. Wrong. The building was constructed for the World's Columbian Exposition in 1893 and for whatever reason the concrete was 18" thick. The contractor had to use giant road saw blades to cut it. inspect and verify.
The crate is so impressive that with 20 minutes of welding and chunk of granite it made very strong patio table.
While everything mentioned about 4-post lifts is correct, for my money they're pointless. What good is a lift where you can't remove the wheels to rotate tires, do a brake job, or anything? The only thing they're good for is storage (and in a normal garage you're NOT getting a second car underneath them) and oil changes. Sorry but 90% of the work I do on my cars requires removing a wheel or four, and I do ALL the work on my cars. You're definitely not getting an engine out on a 4-post lift. Why pay double for something with 10% of the utility?
Best bet for my money is the two-post with a crossbar, which reduces the lift height somewhat but also greatly reduces the axial load on the concrete anchors. Or, as much of a "band-aid" as it may be, the Quick Jacks.
Oh and if you're drilling into concrete, you're using a masonry bit and a hammer drill, and NO masonry bit is cutting through pre-tension cables, and really, who's got pre-stressed concrete in their garage floor? Is that really a thing? That's for bridge spans and stuff.
Flame suit on.
https://www.steeda.com/steeda-s550-m...-555-5205.html
For tire rotation I can put central jack and lift front or rear, but even big garage is not giving you that much space around to play with it.
Having floor jack, I prefer to do it on driveway. That also saves me lifting the wheels.
