2010 MB Eclass W212 replace brake fluid
Does the same procedure work with the MB w212? Or is it more complicated?
Like all brake systems jus be sure you don't run the reservoir dry and use the correct fluid.
https://mbworld.org/forums/e-class-w...2011-e350.html
be rough or be contaminated and pushing the brake pedal to the floor can damage the rubber piston seals.
Stu
