Sponsored by: CARiD
Green and Yellow Coolant - Mixing?
Old May 12, 2019 | 07:08 PM
E350Phil's Avatar
E-350 Sport Sedan
After replacing my thermostat in my 2011 E350, I needed to add back in some coolant. The original coolant is green, and I only had some yellow Zerex G-05, which is also for Mercedes.
Now, I just read that mixing green and orange coolant will cause it to gel and mess up your engine. I'm not sure if the yellow coolant will do the same.
Did I do a big goof?
Old May 13, 2019 | 10:40 PM
belarus27's Avatar
2010 e550 p2
yellow is for models up to june or july of 2011 i believe , so its a NO
Old May 13, 2019 | 10:42 PM
belarus27's Avatar
2010 e550 p2
so before that they used a blue one , if yours is green i would assume it was manufactured after those dates
Old May 13, 2019 | 10:55 PM
DFWdude's Avatar
2016 E350 Sport
Aside from the question whether or not to mix different coolants (no opinion here), once mixed, the result will be a different color, neither green or yellow. Not bad if you can remember which coolants they were... I assume quite bad if you can't.
