Big brake upgrade on w212 for cheap
Generally speaking, this seems like it should be a good fit and easy to do. The braking on all of the other Merecedes that I have owned has been super smooth. I am hoping that this fixes the problem with the pulsating. Any help from other's experience would be helpful. Thanks!
It's kind of dark out after the time I spent cleaning.
Better than when I got them, but do not look good.
Need more work.
I put this bolt into the hydraulic hose connection to prevent water intrusion into the inside of the caliper.
Original '11 E550, 344mm, 64.5mm offset rotor.
'13/'14 E550, 360mm 64.5mm offset rotor.
'13 CLS550, 360mm, 51.4mm offset rotor.
Unfortunately, these calipers came from a donor car from a part of the country where chemicals are used on roads, causing the cast aluminum to become pitted. I was not able to get them looking very good. Here are a couple of photos of the pistons and the rubber pieces around them, showing the part information. I did not replace these. I'll add a follow-up when the swap is finished.
I checked Brembo pages and they dont offer a left and right side disc. This sucks..
https://www.bremboparts.com/europe/e...91/000011393-1
Has anyone done anything to this issue? I checked few aftermarket makers and all had only one brake disc available to the front, so are they all like this?
For my upgrade of a 2011 E550, I ordered 09.B769.51, not 09.B747.51. The 09.B769.51 is the one that normally fits the 2013/2014 E550. The one you mention is 360mm, but has an offset of 51.5mm. I needed one that has a 64.5mm to match the original 2011 E550 spec rotor, 09.B746.51 (only 344mm). If you are upgrading a 2011 E550 and are putting new calipers on, you may need to get the rotor with the 64.5mm offset rather than the one that you ordered which has a 51.5mm offset. Using the 09.B769.51 on my '11 E550 with the calipers that I got from the 2012/13 CLS550 worked great, the 64.5mm offset was right on. I don't know what year/model you have, or if you are swapping out calipers, but just wanted to point that out.
Too bad about the issue with the cooling fins and the fact that the rotors are not made directional.
BTW, my upgrade has been great! There has not been any return of the shuddering and the braking is both smooth and strong! I am really pleased with this upgrade.
Cheers,
BenzX5 (X5 cuz I have 5 Benz)
Here's some project pics. The calipers had some pitting etc, so I painted them silver and 2k clear coated them with new Merced stickers I got off Ebay:
Which is what I did last year, when I put in Brembo rotors to replace the Zimmerman's. 2012 E550's have the same Brembo calipers.
I have a set of these calipers \ Powerstop Rotors and pads for sale - PM for more Photos etc...I was going to upgrade but have not had any issues with my current setup so not going to mess with it.
Would much prefer to meet someone local (Oregon if possible since this is would be a very heavy bunch of items to ship)
Cheers
My S212 currently has 320mm front rotors with basic single piston floating calipers.
Edit: just saw above that someone made this work with their E350. Case closed!
