AC Problem!! AC on Makes car run rough and weak
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
2017 Summer, AC button was flashing then, it turned off my itself. I went back to the shop, found out the Tech didn't properly install AC piping back after turbo upgrade 2017 Apr.
All freon was leaked out.
The tech fixed the AC 2017 summer. It was working 2017 Summer till 2018 summer.
2018 Summer, As soon as i turn on AC, car drives funny. It goes weak and Engine runs rough. exhaust sounds rough too. (Sounds like exhaust leaking)
Car would also bucking, after let go of gas pedal.
During this issue, turning off AC won't get car back to original power back. I have to turn off the car. reset ECU.
I have checked on google.
Search results are saying,
1. AC compressor might be dying. (But it still makes cold air.)
2. Freon is low.
3. too much Freon
4. Engine Issue (I dont think this is the issue, since its running strong without AC on)
Any possible reasons this issue was caused from "The tech who didn't hook up my AC properly after turbo upgrade" ??
I heard some people said, compressor might get damaged if the AC piping isn't connected properly.
Any thoughts ?
2. Freon is low.
3. too much Freon
Any thoughts ?
Received 1,730 Likes
1922 Ford Model T / no OBD
The only way I can figure out for your AC affecting engine run is compressor grinding the internal parts and putting big resistance on the engine.
Take the belt off and try to move it by hand.
And as always - you should start with reading the codes.
When you have to reset ECU - you have to have a code.
You do have MB-oriented scanner?
Mercedes Benz W212 E250
2. Freon is low.
3. too much Freon
Any thoughts ?
2. Freon is low.
3. too much Freon
Any thoughts ?
There is another way compressor can make engine run rough. If your refrigerant fill is way too high the compressor starts to press gas form directly to liquid for, which should not ever happen. From gas to liquid should happen only in the radiator in front of the car.
Those AC systems have high pressure limit switch, so overcharge would fluctuate the load.
I remember, before this issue, as soon as i turn AC button off, it will stop cold air in 1-2 mins.
I guess the only way to find out overcharge, is to hook up to the gauge.
I did!! I scanned it with xentry.
Also with obd2 scanning tool.
Both No codes showing
It's a very strange situation.
If there is code, I would have post it here.
But no code showing at this moment.
This Saturday, I will dig into it.
1. Use gauge to see if it's over charged or too little Freon.
2. Check belt and tensioner.
3. See if anything is grinding on the compressor unit.
You may have an issue with the expansion tube/valve. If it plugs up your high side pressure goes very high and if bad enough can turn gas to liquid at the compressor and definitely would rob lots of power from the engine. High pressure sensor should pick this up and cut it off but if the sensor is bad and does not see the excessively high pressure then the system cannot protect itself.
cocobeex (06-13-2019)
Sounds very time consuming.
Thank you so much for the info!!
Your scanner will read all AC sensors.
I keep posting link to procedure, but for starters, you need to test sensor calibration, meaning reading them on cold morning.
Than 2nd time read the sensors on hot afternoon, when AC should work at max.
I will go in AC category and test sensor calibration.
I will post screenshot if i can later.
Thanks for the info!!!
