CV Axle Break?
Shop called and said Front Drive Shaft destroyed, CAT destroyed and a crack in tranny. Looks like I must've hit something on highway...ugh... good times.
As KEY says, CV joints usually give long warning and when I had CV failure on VW, it simply spin inside.
Than on other forum member was ignoring front driveshaft UV joint symptoms till the thing blow on his driveway setting off several airbags.
I'd call your insurance on this one, (and I never say that). If you hit something and it did this you should be covered. This may total your car. I'd also take it to a dealer for repair if insurance is covering it.
If it is did the front end of shaft fall on road and cause impact on transfer case/gear box and crack it?
