60,000 mile maintenance
There are many factors that negatively impact the quality and performance of fluids, including heat, age, and wear material (fine metal flakes from things like gears naturally wearing down). If the fluid isn't in good shape, it's not lubricating, shearing, or transferring heat the way it's supposed to. All of that means more accelerated wear on the component, and more rapid degradation of the fluid.
The additional kicker with coolant is that not only do the freezing limits change over time, but it will eventually start corroding the cooling system.
Spark plugs also corrode over time, resulting in a degrading quality spark right up to the point where it stops sparking.
You may be able to skate by and never have to change these things in 200k miles, but make no mistake, it's luck. More often than not, you're simply inviting undue trouble upon yourself.
in 30 years you never changed plugs?
WOW did you have high mileage cars? I they will still run with old plugs but they run so much beter with new ones when manufacturer says you need new ones.
Normally they have you replace them to ensure you still pass emissions and get good MPG.
Judging by your first post, you have not owned many cars or haven't owned high mileage ones.
That or you are just oblivious to cars not running properly.
Do what the dealer recommends, besides the coolant.
Not necessary until 15 years or 150k miles.
https://www.shell.us/business-custom...r-locator.html
As others said, I'd skip the coolant flush. I'd check the oil cooler gaskets for leaks also. I'm over 120k at this point. I've also changed the thermostat, idler pulleys and tensioner. When you change out the thermostat you lose half the coolant anyway so I figure I've already had half the coolant flushed. The old stuff looked fine.
"A" service
-10k 30k 50k 70k 90k and so on
"B" service
-20k 40k 60k 80k 100k and so on
7G-Tronic transmission service
-40k 80k 120k 160k and so on
Spark Plugs/Engine Air filters
-60k 120k 180k and so on
100k Miles
-Rear Diff fluid
-Front Diff fluid
-Transfer Case fluid
