Sponsored by: CARiD
Battery replacement
Old Oct 28, 2019 | 04:13 PM
lakepop's Avatar
2011 E350, 2015 E350 Sport
Lightbulb Battery replacement
Have a 2015 E350 that I need to replace the main battery. I need to know if there is anything special I need to know. My concern is I will be replacing with a non Mercedes battery and also if I need to have a power source connected while I change the battery. Will I lose anything when i disconnect the battery ?
Thanks for any inputs....
Old Oct 28, 2019 | 04:22 PM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
I have a 2014 E350 and I replaced it with a genuine battery. Didn’t need to connect any trickle charger when replacing. Worse case senario, you lose synchronization of the windows
Old Oct 28, 2019 | 05:53 PM
Arrie's Avatar
I have disconnected my battery many times without any other power source connected with no issues what so ever. Even the clock goes back to correct time when I re-connect the battery. I guess AUX battery keeps the clock on time.
Also, I would not connect just a charger of any kind without a battery connected at the same time. Chargers, as good as they may be, can output "dirty" power meaning it is not pure DC. This can do harm to some fine electrical parts.
Old Oct 28, 2019 | 07:32 PM
lakepop's Avatar
OK......got it done...battery IN with no issues. Thanks for the inputs...
