Headlight adjustment
My passenger headlight seems to be lower than my drivers side is there an adjustment on them to raise it up? My high beam seems really low but they both need to be moved up to match drivers side. Any help much appreciated. It’s a 2013 e350.
If you open the hood and look at the black metal brace over the headlight, you will find a round hole. If you peek through there, you should be able to see the top of the headlight housing with a plastic hex shape in there. You will need a hex bit and a short extension. Turn it one ay and it will raise the beam. Turn it the other way and it will lower it.
adzeladini (11-19-2019)
