looking for a full copy of a bulletin...
Konigstar, can you help? I tried to message you but looks like you don't allow them?
16 E550 Cab, 2003 Ram bright red crewcab 4x4 we call Clifford :)
https://www.tsbsearch.com/Mercedes-B...68-30-P-053962
i found this too... but no pdf that i can find...
Mercedes Benz E 550 4MATIC Sedan Technical Service Bulletin # LI68-30_P-0539622 Date: 130314
Mercedes-Benz Mercedes Benz OEM Parts Mercedes Benz OE Replacement Parts
Interior - UV Radiation Fading Of Wood Trim
Fading of wood trim in model series 212
Topic number L168.30-P-053962
Version 2
Design group 68.30 Coverings, trim
Date 03-14-2013
Validity Affected vehicles up to:
MODEL 212 with CODE (731) Burred walnut veneer
wood finish trim
MODEL 212 with CODE (W 60) Burred walnut veneer
designo wood trim, brown
Cleanpoint August 2011
Reason for change Removed non-US specific parts due to confusion with
parts ordering.
Complaint:
Fading of the burred walnut veneer wood finish trim parts.
Cause:
UV radiation can cause fading in some cases.
2010 Mercedes Benz E 550 4MATIC Sedan (212.090) V8-5.5L (273.970) Page 420
Remedy:
Affected vehicles:
MODEL 212 with CODE (731) Burred walnut veneer wood finish trim
MODEL 212 with CODE (W 60) Burred walnut veneer designo wood trim, brown
Parts kits of burred walnut veneer wood finish trim are available from the GLC in the event of complaints.
In order to rule out the possibility of installing the wrong parts, check the date of manufacture on the rear of each component.
Parts kits with parts earlier than cleanpoint August 2011 should be returned to GLC. Encode the affected component with damage type
Symptoms
Parts
Work units
Version 2
Date 03-14-2013
wood finish trim
parts ordering.
Complaint:
Cause:
Remedy:
Affected vehicles:
Symptoms
Parts
Work units
2003 SL55 | 2004 E320 4Matic Estate | 1996 S420
https://drive.google.com/file/d/1lZk...ew?usp=sharing
Received 4,435 Likes
'71 Pinto
For the asking...
