Sponsored by: CARiD
E350 Suddenly Went totally Dead - No Power at all
Old Nov 21, 2019 | 03:11 PM
jwilock's Avatar
E350
I took my 2012 E350 Bluetech in to get the tires rotated. They called me to pick it up. When I got there about 30 minutes later and went to drive home I found the car totally without power. No dome light, dash lightsa , power windows, power locks, no "click-click" when I try to start it. Nothing. The tire people brought a jumper out but it registered my relatively new battery as having full power and connecting the jumper did nothing. Something suddenly went very wrong. Don't think the tire people could have done anything even though the timing is strange. Doesn't seem like a key problem as there are no lights, no power to the windows and door locks, etc. Also doesn't seem like a battery problem as the battery is showing fully charged (and would not likely have gone from running fine when they parked the car to everything totally dead a half hour later). Anyway the car is now sitting it their parking lot. Before I call someone to tow it to a dealer I thought somebody here might have an idea or suggestion. Oh, I did check to make sure the battery cables are still connected and look to be in good condition.
Old Nov 22, 2019 | 11:03 AM
pgsurface's Avatar
83 300D 617T(retired), 96 E300 606n/a(retired), 99 E300 606T(retired), 07 E320 BT, 14 E3504M
Grab a 10mm and check the battery terminal connections under the hood. Make sure they are not loose. If you can grab the wire and wiggle it enough to allow the terminal to move, tighten them down.
The only thing that would kill all your systems like that is loss of electrical power.
Old Nov 22, 2019 | 01:13 PM
fc3's Avatar
fc3
2016 E400 Sedan, 2018 E400 Cabriolet
Bad fuse or fusible link? There appears to be something like that on the battery. Worth checking as it would only take a few minutes with a DVM.
Old May 4, 2020 | 07:34 AM
Gee Pee's Avatar
C350
Question
Hey Jwilock, did you ever find out what happened? My friend just called me that his e350 from walking into the house with groceries to returning 5 minutes later to go somewhere... is doing absolutely nothing. No click, no light, no door opening, as if somebody took the battery out.
