Sponsored by: CARiD
Torque specs on ngk spark plug
Old Dec 1, 2019 | 03:13 PM
rohanpatel14's Avatar
ml55 amg
2011 e350
im planning to change the spark plug on the car but I cannot find torque spec on the ngk for this car. I know Bosch plug on torque to 23 nm.
Old Dec 2, 2019 | 07:18 PM
ml55 amg
No one?
Old Dec 2, 2019 | 07:21 PM
Arrie's Avatar
Originally Posted by rohanpatel14
2011 e350
It is the same torque regardless of brand you install.
Old Dec 3, 2019 | 11:40 AM
fc3's Avatar
fc3
2016 E400 Sedan, 2018 E400 Cabriolet
The question is: will the NGK index correctly?
Old Dec 3, 2019 | 01:41 PM
atraudes's Avatar
2011 E350 Wagon, 2010 GL450
OP has an '11 which has the M272. I thought only the M276's plugs needed to be indexed?
Old Dec 3, 2019 | 03:19 PM
fc3's Avatar
fc3
Some of the M272s have DI, particularly the 3.5L. Don't M-B DI engines require indexing of the spark plugs?
Old Dec 3, 2019 | 03:37 PM
atraudes's Avatar
Ah yeah the CGI uses direct injection. I believe all DI engines should have their spark plugs indexed, yes. The non-DI engines don't require it though, right?
Old Dec 3, 2019 | 04:11 PM
fc3's Avatar
fc3
I don't know. I'm actually a little surprised that the M276 DEH engines require indexing, but many here say that it does. Logically, if the charge is homogeneous, then the mixture should be ignitable whichever way the plug's gap faces. I can see where it makes a huge difference in the DES engines because only in the vicinity of the spark plug, and probably mostly on the side nearest the injector, is lambda 1, stoichiometric. Elsewhere in the combustion chamber, the mixture is leaner, perhaps too lean to ignite or lean enough to ignite, and burn at a too hot temperature. Lean is a funny thing...
I need to order the factory manuals and read them. I've read the FSMs cover-to-cover for all of the other cars I've owned, as well as the boats and PWCs.
Old Dec 6, 2019 | 01:46 PM
ml55 amg
I do not have DI. I have no do engine. So 23 nm okay with ngk.
Old Dec 6, 2019 | 02:13 PM
konigstiger's Avatar
'71 Pinto
23 Nm
File Type: pdf
