Sponsored by: CARiD
Anyone buy this Console Storage Tray for Facelift W212?
Old Jan 6, 2020 | 05:58 PM
DFWdude's Avatar
2016 E350 Sport
My storage tray and door pockets arrived today, finally... 2-weeks overdue.
I will try to install them tomorrow and maybe take a pic or two.
Old Jan 6, 2020 | 07:26 PM
nightspd's Avatar
2016 E-350
Great, can't wait to see it!
Old Jan 6, 2020 | 10:08 PM
Joe Alonso's Avatar
2016 E350 Base
Got mine...
I got mine already from eBay. Here's the original link:
https://www.ebay.com/itm/Central-Tra...72.m2749.l2649
Bought it 11/26/19; received on 12/17/19. Fits real good. I do know that to lift it up, it's a bit of a pain (not too much) because you have to grab the elevated middle plastic divider and pull up. If you have your USB cord going thru the intended whole, it will obstruct the lifting on the unit somewhat.
Here's the item placed where it goes:
And for those seeking inside handle buckets, here's mine and the link to where I got them:
https://www.ebay.com/itm/Fits-Merced...72.m2749.l2649
Old Jan 7, 2020 | 05:13 PM
DFWdude's Avatar
2016 E350 Sport
Here is the console tray (for 2-USB 2016 model)... Well made and fits perfectly...
And the Door Pocket. Nice, sturdy fit. I wasn't sure if I would like the Black color, but they fit in well with the other (black) door fixtures...
Old Jan 7, 2020 | 05:20 PM
Joe Alonso's Avatar
2016 E350 Base
Nice!! I like the contrast of the handle buckets with the light interior. Congrats.
Old Jan 7, 2020 | 06:06 PM
nightspd's Avatar
2016 E-350
Are the USB ports obscured by the console tray?
Old Jan 7, 2020 | 06:22 PM
  #32
DFWdude's Avatar
2016 E350 Sport
Well, of course the USB ports are below the tray. I have USB Music storage plugged into the ports, so I don't need frequent access to them. However, if you want to plug a USB cable into the lower port for Android Auto (if equipped), the cable is easily routed through the provided slot in the tray (RT side in picture) to plug into your smart phone. (See picture in post below)
Old Jan 8, 2020 | 11:37 AM
  #33
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
Finally got around to installing mine as well. I ordered mine through AliExpress.
This is the 2016 2-usb version.
​​It fits perfectly. It's not tight - I would say just shy of snug so I didn't have the need to install a loop to pull it up.
The door pockets on the other hand, although snug, they do not secure enough for my taste. I'm considering applying some type of tape or adhesive to keep them from sliding out
Old Jan 8, 2020 | 01:21 PM
  #34
93srvman's Avatar
2016 E550, 2018 GTC
Did you order for all 4 doors if you have a sedan? Note my post above if so.. I had the fronts/rears revered at first which caused the fitment to not be great, especially in the front. Reversing as everything now nice and tight.
Old Jan 11, 2020 | 02:04 PM
  #35
DFWdude's Avatar
2016 E350 Sport
Yes, that tray is fiddly to remove once in place.
For now, I decided not to drill the center divider to install a ziptie pull ring. Instead, I've installed a tab of Black Gaffer's tape at the balance point of the tray. It will not come loose easily, and can be folded over to lay against the divider when not needed. Works very well.
Old May 22, 2020 | 04:19 PM
  #36
wdbii's Avatar
2013 E350 Kombi
Bringing this back from the dead a bit. Thanks to those who posted images and so on. I ordered the console organizer and door handle pockets. The organizer is coming from S. Korea, so tracking should be, uhmm, interesting. The door handle pockets arrived already! I'm really happy somebody makes these because the door handle was my go-to place for sunglass storage in my last car and I'm a creature of habit. The pockets I got have a cute little rubber pad that goes in the bottom.
Old May 22, 2020 | 04:35 PM
  #37
DFWdude's Avatar
2016 E350 Sport
Yep, the door handle pockets are very useful. Also keeps finger oils from staining the beige interior.
They do fit tightly, though, which is good. But I wonder what indents they will make in the upholstery around the pouckets over time.
Gotta accept one thing to get another, I guess.
Old May 22, 2020 | 05:59 PM
  #38
manishjain24's Avatar
W212 E400 4Matic < W211 E350 4Matic
Interestingly there is a wireless phone charging option, but not available for E class. Nevertheless a great organizer.
https://www.aliexpress.com/item/3288...7%237558%23119
Old May 22, 2020 | 10:28 PM
  #39
pb39374's Avatar
2010 E350 4Matic sedan
yep, I got the same tray and door handle pocket inserts. Very useful. In addition, for your sunglasses, you should get this sunglasses holder. It installs in place of the handle above the drivers door. All you need to do is remove the handle and then install this holder. I love it and my glasses are in it all of the time when not in use.
https://www.ebay.com/itm/Sunglass-Ho...YAAOSwPCVYAHoh
Old May 23, 2020 | 07:44 AM
  #40
DFWdude's Avatar
2016 E350 Sport
Neat idea. But I actually use the driver assist handle, to avoid tugging on the steering wheel when exiting the vehicle. (There's that small plastic part in the wheel that can break.)
Old May 23, 2020 | 09:05 AM
  #41
wdbii's Avatar
2013 E350 Kombi
It's also on order, from ECS.
https://www.ecstuning.com/b-genuine-...0481000419051/
I originally saw it in one of Doug DeMuro's videos about his E63 AMG wagon, and was disappointed to find that my car had a grab handle instead. So I went searching and found it at ECS. I found it on eBay too, but went with ECS in the hopes of avoiding interminable shipping times from overseas. Even ECS quotes a 5 day lead time prior to shipping though. So I guess I'll see.
Old May 23, 2020 | 09:17 AM
  #42
pb39374's Avatar
Yeah, if you utilize the handle then no point installing this holder. But, you can also install the sunglass holder on the passenger side, if you wanted to 😀
