Differential Fluid change
2010 E350 4Matic sedan
I have a 2010 E350 4Matic and was wondering if the rear and front differential fluid needs to be changed. I don’t see anything in the maintenance booklet for it (other than for AMG’s). Does anyone know?
AMGs I think have it in the booklet because the differential has a mechanical lock with wearing parts in it.
I don’t know about yours, but mine (2014) is easy for the rear diff and a PIA on the front due to no fill plug. Have to remove Axle shaft to refill. My mechanic says the rear is serviceable because it takes the workload due to a fixed split of power via the transfer case and rear biased (believe 55/45 back/front). He said they’ve never seen a front diff go bad due to gear oil.
Tmqdoc1 (08-01-2020)
2014 E350 Sport 4Matic Sedan
What have each of you used? Did you find any particular recommendation?
Received 1,488 Likes
I changed the axle seal in my car and had to change the differential fluid. As it only held .6 quarts and the oem fluid from FCPeuro was around $20, I didn't bother chasing any other fluid. Some have claimed they got better gas mileage from going back from a 75w-90 to the oem 75w-85 but I find that a little hard to believe. My guess is that redline isn't on MB's approved fluid list which is why it's just recommended and not MB approved.
Received 4,435 Likes
'71 Pinto
Clean screws and holes using Loctite cleaner or equivalent, apply a drop of sealant to start of lower thread on drain plug and tighten.
pierrejoliat (06-05-2020)
