Sponsored by: CARiD
Need Help with Front Height Level Sensor Installation
Old Feb 1, 2020 | 12:49 PM
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
I'm in the middle of a retrofit project and the only thing I'm stuck with is how to connect the front height level sensor to the suspension. My car did not come equipped with it so I don't know how it's supposed to be installed.
It has a bracket at the end of the arm that reaches various suspension components but I can't figure out where it's supposed to attach.
My car is a facelift W212 (2016).
A diagram, picture or any info is greatly appreciated
Old Feb 1, 2020 | 03:08 PM
konigstiger's Avatar
'71 Pinto
See if this helps.
Old Feb 1, 2020 | 07:02 PM
That's exactly what I needed. You came through as always - much appreciated
Here's some closeups in case they can help someone else out
Old Jan 13, 2022 | 03:02 AM
Jobba's Avatar
E 220 Wagon, 2012 mod.
Length of linkage/rod
Anyone know or has the opportunity to measure the length of the linkage/rod on this sensor ?
I have a 2012 mod E 220 where the rear suspension is sitting a bit high, and fount that the Linkage/rod is missing on the left front height level sensor, according to MB dealership this rod is not in their partlist, only a complete new sensor, so i would rather make one myself then..
Old Jan 13, 2022 | 07:54 AM
Never measured it, but I can tell you that they are very sensitive to the slightest variations.
You might be better off buying a used sensor on eBay or a junk yard and use the rod off of it.
(P.S. If you replace the entire sensor, you will need to have it re-calibrated).
