Ancestry of E Class
Took over a week, but I got the answer. No longer have the email, but I quoted it somewhere on benzworld if you'd like to search for it.
Anyway, the E- classification come to life about 1995, so long after quoted 1952.
Earlier car of the size was W123 and W124, who were marked as 300-series.
Actually it was W124 who in last year was sold as E-class.
It happen to me 2nd time few days ago, that noticing new MB in front of me, I tought "the new E-class is getting smaller and smaller"
Only 2nd look let me notice S badge.
I think the E originally referred to fuel injection.
Of course no car of today is a direct descendant of any cars made many decades ago. The current Chrysler 300 is nothing like the original Chrysler 300's for example.
I did own all mid-priced MB sedans starting with 1985 models.
W123 was a tank.
W124 more sophisticated, but lighter and handling was so-so.
W210 regain the tank-feeling
W211 is lighter again, but suspension went high-tech. New technology, more gadgets took some interior space, so the car feels smaller inside
W212 packed the gadgets better, so interior feels roomier even outside measurements I think are smaller. MB, who I prize as being on conservative side, with W212 went with market trend and put low-profile wheels on the car. Now big % of topics in W212 section is about wheel repairs.
Here is one specific to the E-Class...
The You Tube link went back to 260D of 1936(?) and then traced up until W212. This is a visit to an M-B museum in Germany. Listed W136, W120, W110, W114, W123, W124, W210, W211, W212. W124 (84-86) was first called E Class. Noticed one site referred to E Class as the Executive Class.
https://www.mercedes-benz.com/en/cla...es-benz-170-v/
E means Executive
C is Compact
S is Super(4 door)
SL is Super Leicht(Super Light)(2 door)
SLK is Super Leicht Kurtz(Super-Light-Short)
CL is Coupe Leicht (Coupe-Light)[now called the S Class Coupe]
CLK was Coupe Leicht Kurtz(Coupe-Light-Short)[now called the E Class Coupe]
G is Geländewagen
E means Executive
C is Compact
S is Super(4 door)
G is Geländewagen
The original Mercedes letters were suffix:
Carburated models came with just model number no suffix - e.g. 200, 280S
Diesels had D suffix - e.g. 240D, 300SD
Fuel injected gasoline engine had E suffix e.g. 230E, 280SE
Coupe body had C suffix - e.g. 280C
Wagon body had T suffix - e.g. 230TE
So the suffix means either diesel or fuel injection, or an alternate body (standard sedan had no suffix). The only classic Mercedes suffix that didn't conform to the standard was SL. It stands for Sport Leicht and not a description of bodystyle or engine.
Until the early 2000s, they came with a soft top and for most there was a removable hardtop optionally available. Since then, the tops have been retractable steel. One of those removable hardtops famously called the Pagoda.
From 1952-56 the the 300SL was a coupe, but it became only a 2-seat convertible in 1957 ... and had the 190SL for a partner.
During the early 1980s there was the SLC, which was a fixed top version of the current (107) SL, the only time that designation was used ... until the name was recently revived to replace SLK.
The SLK/SLC is still a 2-door convertible, a shorter (K) one. Kind of like your Walther PPK.
As for E-class, the majority of W124 sold in USA were 300E and many started calling them E-class. Mercedes made this official with the facelift versions, including E320. 190 was an old-time traditional Mercedes designation, but it soon became obvious there would be bigger engines installed, and the "baby benz" became the C-Class. E = einspritzer, the correct spelling.
The numbers on MB usually indicate engine size.
But before lettered class indication arrived, the 300-series cars were equipped with 2.3l (and other) engines.
I did own W124 who was marked as "300DT 2.3"
On the flip side, Mercedes used to "under label" its large engine "S-class" fullsize models both in US and Europe so the car attracts less attention. For example, the W111 280SE 3.5 had 3.5 V8 but stuck with the 280 name that normally applied to the 6 cylinder model. And the W116 450SEL 6.9 was definitely 6.9 liters but it stuck with the 450 name for the same reason. That didn't change until W126 came out and the top model gained the 500 (and later 560 name).
