2012 e300 4matic - Steering Wheel Malfunction
My problem now is after they changed it and switched out the tyres, I had no PS
after scanning it, C159300 code comes up , steering torque sensor
My question now is is the whole steering rack one unit with the sensor ? is this a dealer only part ?
is this part vin coded ?
also how did this happen ? the shop said they banged on the tie rod end to remove it , not knowing it was an electric steering ? does this make any sense ? is the system that sensitive?
is it maybe a wrong outer tie rod end part causing this ? or the banging that broke it ?
I used the search function and couldnt come up with anything on the forum or via google
any input on the situation will be appreciated
