Sponsored by: CARiD
2014 E350 No Audio
Old Apr 18, 2020 | 01:41 PM
Billyismyname's Avatar
W221/W222/W213/X290
2014 E350 No Audio
I know i've made a thread previously for this but I thought I'd make a new one to clear somethings up.
My audio cut out while I was driving on the highway. Music was playing and out of no where the sound cut out. The below is what i have checked and replaced:
- AMP
- Fuses
- Relays
- Cleaned off the fiber connections on the COMAND head unit and every other Fiber end I could find (In the trunk also)
- Did a hard and soft reset of the COMAND unit.
- With STAR computer, did a hard rest of the COMAND unit as well.
Sound for the emergency SOS calling works. I hear sound come out of the speakers and it rings, but no sound through FM, AM, Bluetooth, AUX, etc.
I was literally going to trade in the car because I am out of options here. Only other thing left to replace would be the main battery and AUX battery. My Start/Stop feature doesn't seem to be working and the other day my car would not turn on because the battery was fully drained. Could this be the problem? I had a ESP light as well but that was because of the battery, so i am wondering if the battery could have anything to do with the sound?
I took the car to a local Mercedes dealership to look into it, but of course like 90% of the Mercedes dealerships they'd rather steal your hard earned $160 for the hour than to actually tell you what's wrong. They said that their computer "cannot communicate with the COMAND head unit". I find that either to be a Fiber cable is bad or maybe something with the battery causing components not to work properly? the dealership said they "need another $500 to diagnose the issue and take apart the front panels and trim".
Old Apr 19, 2020 | 12:50 AM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
You may need to go into engineering mode and view the amp settings. there’s a setting for external amp and internal amp. Check to see if External Amp is selected. It should be selected.
Old Apr 20, 2020 | 02:18 AM
W221/W222/W213/X290
Yes, I've done that as well. Diagnostics show that the AMP is "NG". Not sure what that means but I guess there is no communication somewhere. I believe that the AMP is good.
Old Apr 20, 2020 | 10:36 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
The NG on the amp diagnostics means the car thinks the amp is no good. Are you sure it has not gone out?
Old Apr 27, 2020 | 01:35 AM
W221/W222/W213/X290
I could be wrong, but it still shoots out Fiber light when I un plug the connector. I am taking it to a shop this weekend to have them look into the optical loop and the individual sound devices.
Old Apr 27, 2020 | 07:35 AM
LILBENZ230's Avatar
Pablo - replace the battery first. That should be step 1. Low voltage from weak batteries cause all sorts of paranormal behavior in Mercedes cars.
Old Apr 27, 2020 | 04:30 PM
W221/W222/W213/X290
I really should have done that. However, now that MB of Manchester NH broke my head unit after trying to fix it, I have to figure out what exactly is happening. I believe there could be a bad AMP or optical ring gone bad somewhere. I am bringing it to a shop here in Manchester NH that works with Porsches and Lamborghinis (other high end cars too) and they have the computers for it,
