Sponsored by: CARiD
back up camera stopped working, need wiring diagram
Old May 4, 2020 | 02:27 PM
andress1021's Avatar
2016 E350
hey guys I need your help, if anyone has the link to the backup camera wiring diagram or any info so I can diagnose it please, bought my dream car but backup camera stopped working and its not under warranty, when I put it on reverse screen does nothing, 2016 E350 4MATIC.
Old May 4, 2020 | 03:31 PM
konigstiger's Avatar
'71 Pinto
Start by checking fuse, f84 @ rear SAM in trunk. Fine, remove trunk panel to access harness, check camera connector/connection. Camera replacement part # is 2189050902 if need be.
File Type: pdf
File Type: pdf
Old May 5, 2020 | 09:40 AM
2016 E350
F84 (5amp) fuse in trunk passenger side fuse panel is good, is there anything else I can check, power? ground?, the last think I want is start throwing parts at it, most electrical parts are non returnable at least the dealer that I asked.
thank you for your help I appreciate it.
Old May 5, 2020 | 09:52 AM
'71 Pinto
As suggested short of having someone pull fault codes using Xentry (MB diagnostics) visually inspect connection & harness run through trunk.
Old May 5, 2020 | 10:01 AM
2016 E350
yes, already inspected harness which runs along the left side of the trunk lid down through the left side of the trunk, everything checks ok.
