Sponsored by: CARiD
Brabus style diffuser and exhaust tips
Old May 11, 2020 | 09:34 AM
kadoemon's Avatar
W212
Question Brabus style diffuser and exhaust tips
Hi
I have a problem in brabus style diffuser and exhaust tips.
I hope someone can help me.
My car is W212 E250 in MY 2015.
I buied brabus style diffuser and exhaust tips from china.
Diffuser already install on my car.(But fitting is bad...T-T)
However exhaust tips can not install.
I do not found that how to fix tips brcket in car.
Does anyone installed exhaust tips in W212?
Old May 11, 2020 | 02:33 PM
Bhopkins's Avatar
2014 E350 Sport 4Matic Sedan
Contact the folks in China that you bought it from. Take lots of pictures, showing what is supposed to fit, and where it is supposed to fit, and detail of why it doesn't fit. Sent it all to them. Many of these Chinese companies are very good at customer support.
Unless someone here has the very same kit, you are unlikely to find help here. That's why I'd recommend contacting the manufacturer.
Old May 12, 2020 | 10:03 AM
kadoemon's Avatar
W212
Thanks rep.
Of course I already talk to china seller.
But I do not get enough answer. I requested manual or photo , however they do not send this.
I suspect that Bracket is not for W212. But Seller said "We have this bracket only."
This isn't going anywhere...
So I post this topic.
If can be found same case , I'm lucky.
Old May 12, 2020 | 02:21 PM
Bhopkins's Avatar
Ah. OK. Hopefully you can find someone that has the same kit and can help good luck.
Old May 12, 2020 | 02:24 PM
DFWdude's Avatar
2016 E350 Sport
Brabus manufactures their parts in China? LOL
Old May 12, 2020 | 02:38 PM
nota_amg's Avatar
2013 SL550 BiTurbo
Take it easy Dude...you can see the OP put Brabus"style" tips, not Brabus...smh
anyway, I believe these tips and brackets are for mounting to the stock diffuser and you clearly have the Brabus style C/F one. More than likely, you'll just have to go to am exhaust shop and have them weld the tips to you exhaust pipes in the correct position. Easy-peasy.
Good luck!
